HELP: BOOST problems
Old Jun 7, 2006 | 04:35 PM
integrarj's Avatar
Default HELP: BOOST problems
aight earlier i was on the highway in full boost and all a sudden the boost just died like if the cgarge pipe came off the turbo but it didnt i checked all my pipes and clamps and tightened em tighter then they were and i still have this problem. the turbo is still spoolin, i can put my hand over it and it sucks hard. wtf this shit is pissin me off im ready to just sell everything.
Old Jun 7, 2006 | 05:34 PM
chuckyarus's Avatar
chuckyarus has disabled reputation
Default Re: HELP: BOOST problems
Did you give it another road test. Could it be a type of fuel cut?
Old Jun 7, 2006 | 05:37 PM
D.Nick's Avatar
You check your wastegate? Mine came loose at the track and I lost some boost.
Old Jun 7, 2006 | 05:40 PM
check fuel, wastegate, and check if ur BOV isnt leaking
Old Jun 7, 2006 | 06:02 PM
integrarj's Avatar
when im in my car the boost gauge just stays on zero but i can here the turbo winding up, i have plenty of fuel
Old Jun 7, 2006 | 06:03 PM
integrarj's Avatar
and no nothin is loose
Old Jun 7, 2006 | 06:04 PM
D.Nick's Avatar
Go outside...check your wastegate and BOV. If it still pulls check your boost gauge.
Old Jun 7, 2006 | 06:12 PM
integrarj's Avatar
nothing is loose ive checked several times today
Old Jun 7, 2006 | 08:15 PM
WALL-E's Avatar
WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E
What kind of bov do you have? Mine broke and stayed open, my turbo would spool but the bov let all the boost out, that might be it.
Old Jun 8, 2006 | 08:07 AM
sohc_mshue's Avatar
yea i'm stumped on this. We were tuning, did a pull, it hits 12psi and then the boost just starts dropping off throughout the rest of the pull. Charge pipes seem to all be connected solid, turbo still spins fine, we 2stepped the car to see if any air came outa the bov and it didnt. Wastegate isn't opening prematurely. Its weird.
