B16 turbo Problem
Old Mar 20, 2006 | 02:34 PM
vaspeedjunky's Avatar
vaspeedjunky
Default B16 turbo Problem
Ok my boy just installed a turbo on his 2000 civic SI and it will not boost. We think that the wastegate is messed up. It feels like the turbo builds up boost but you only feel like 1 or 2 PSI. It has a external wastegate and has 3 nipples on the wastegate and we are not sure if we have the vacuum lines hooked up right. can someone maybe post some pics of there B16 turbo. or let us know how they hooked up there wastegate.
Old Mar 20, 2006 | 03:46 PM
sohc_mshue's Avatar
Default Re: B16 turbo Problem
What kind of wastegate? The vac line needs to run to the side port of the wastegate. If you have an electronic boost controller then you will utilize the side and top ports.
Old Mar 20, 2006 | 04:37 PM
vaspeedjunky
where is everyone running the vacuum line to on the motor from the wastegate and the BOV also.
Old Mar 20, 2006 | 05:11 PM
SlowLS's Avatar
Sumospeed #O.G.
Even if the vacuun lines are not hooked up right, should still run off the wastegate spring. Are you sure there is a spring in it, if so how much boost will the spring hold?
Old Mar 21, 2006 | 02:54 AM
vaspeedjunky
could it be stuck open. Or could it be another problem. It does not even build up enough pressure for the BOV to go off.
Old Mar 21, 2006 | 04:30 PM
allmotorSOHC's Avatar
Owner
allmotorSOHC has disabled reputation
did you put a good turbo on there? sounds like more than just a wastegate issue.
Old Mar 21, 2006 | 04:45 PM
SlowLS's Avatar
Sumospeed #O.G.
any boost leaks?
Old Mar 22, 2006 | 05:09 AM
Enigma's Avatar
Check for all piping leaks, check all vacuum lines, check the wastegate to make sure it isn't sticking or faulty, check the spring (if there is one), check for all exhaust leaks... pretty much, go back over everything you did.
Trevor
Subie2Honda
Jan 16, 2009 01:07 PM
mattpowers
Sep 29, 2008 07:05 AM
singlecam4life
Sep 7, 2008 02:05 PM
94 Teggy
Dec 27, 2004 09:36 AM
EG1sol
Oct 16, 2004 07:27 PM
