B16 problem, please help!
Old Oct 16, 2004 | 04:02 PM
EG1sol's Avatar
EG1sol has disabled reputation
Default B16 problem, please help!
Hey guys, I have a 1993 del sol S with a swapped jdm B16. I have been having bad luck with this thing since the swaps done this summer. The synchros died on reverse and 5th so I had to get the thing rebuilt and that cost a ton. When I got my car back from the guy who did the swap he said the Idle Air Control Sensor was missing and he put a "blank plug" in so the car would start( but the shop that did the transmission said the IACV was there and did not know of any sensor for the IACV)?, also that a plug near the TPS and throttle body was cracked. Now for the problems, the revs jump at 1500rpms to 1600rpms, which sucks if your driving and you hit that area in the rev range, it shakes the shit outta my car. Also whenever I hit the gas or let off the gas the car violently shakes, and sometimes the pedal would seem somewhat stuck when Id get into the car in the mornings at first. I know the throttle cable from my old motor was used, and the spring that its connected to was from the new motor, and the spring seems very stiff at times. Does anyone have a clue as to what would be causing these problems? Any advice would be greatly appreciated.
Old Oct 16, 2004 | 04:26 PM
IC x Prince's Avatar
IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince
Default Re: B16 problem, please help!
adjust your tps. that's what my gsr did. but it was surging...1000 to 2000.
Old Oct 16, 2004 | 04:45 PM
EG1sol's Avatar
Thank you.
Old Oct 16, 2004 | 04:51 PM
you might need to take your throttle body off. honda put these wierd screws (the us motors anyway) that dont' allow you to loosen them. i cut a slit into them and used a flat head and replaced them torx bit screws. hope this fixes it.
also i had a problem where the idle was 2,000 and stayed there. it was the plunger in my iacv. i took it apart and screwed it back in.
Old Oct 16, 2004 | 05:29 PM
EG1sol's Avatar
Thank you for your help man, Ill check the TPS and throttle body tommorow morning, my idle seems normal which really makes this tough to figure out. Right now Im really concerned with the throttle making the car shake, cause I have a sweet 80 mile round trip commute everyday, so hopefully Ill figure that out tommorow.
Old Oct 16, 2004 | 06:30 PM
Quikteg's Avatar
Quikteg is an unknown quantity at this point
Start by getting an IAC valve, if you don't have one as that will help with the idle. Also look into vaccum lines (make sure there are no leaks) and the tps sensor to make sure its calibrated (closed throttle ~.5 volts to WOT ~4.5 volts). Good luck!
Old Oct 16, 2004 | 06:52 PM
EG1sol's Avatar
The shop I just had the car at said I do infact have an IAC valve in place, I will try the TPS tommorow though, thanks.
Old Oct 16, 2004 | 07:27 PM
The IACV doesn't matter unless the throttle plate is completely closed, so it's not that. Also, you would get a IACV CEL if you had a big problem with it (or if it wasn't there)...
Subie2Honda
Jan 16, 2009 01:07 PM
mattpowers
Sep 29, 2008 07:05 AM
singlecam4life
Sep 7, 2008 02:05 PM
vaspeedjunky
Mar 22, 2006 05:09 AM
94 Teggy
Dec 27, 2004 09:36 AM
