1996 integra lost power on interstate will not start
Old 05-24-2010, 02:18 PM
fritz92's Avatar
fritz92 has disabled reputation
Default 1996 integra lost power on interstate will not start
i was driving my integra home on the interstate when it lost all power and had to get it towed home. when i got it home it seemed like i could still hear the fuel pump turning on, so i dont think its a fuel issue, but i pulled a plug and it isnt getting spark, car will turn over but doesnt fire. maybe it is a coil or something, but any advice someone has is appreciated. its a 96 integra with the original b18. when my dad pulled of the distributor cap, he said that the rotor (rotor button) inside was not turning when i was turning over the engine, so idk if something internally is broke. thanks and id appreciate advice from anyone who might have a clue.
fritz92 is offline
Old 05-24-2010, 02:47 PM
Shoryuken!
Snoop 95's Avatar
Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95
Default Re: 1996 integra lost power on interstate will not start
Pull the valve cover to see if your timing belt is broken. Because thats exactly what it sounds like.
And DO NOT turn the motor over anymore until you confirm that it's broken or not. If it is, you don't wanna risk bending any valves.
Snoop 95 is offline
Old 05-24-2010, 03:03 PM
fritz92's Avatar
ok thankks for the info ill see what it looks like
fritz92 is offline
Old 05-24-2010, 04:44 PM
Yes, leave it alone until you can find out what you're working with. A non-rotating rotor doesn't usually mean good things. Luckily it's really easy to take off the valve cover and look at the timing belt to see if it's broken. You might just have a broken distributor, but either way you don't want to be cranking the engine, period. If you do you risk doing further damage without finding out anything useful.
Old 05-25-2010, 12:48 PM
fritz92's Avatar
ok, thank you
fritz92 is offline
Old 05-25-2010, 03:28 PM
SYCKDC23's Avatar
SYCKDC23 has disabled reputation
def sounds like timing belt... either broken or missing teeth
SYCKDC23 is offline
Old 05-25-2010, 05:24 PM
fritz92's Avatar
ya car has 155000 and im starting to think it never had a belt change, i just hope it didnt bend a valve or do further damage.
fritz92 is offline
Old 05-25-2010, 06:23 PM
OM NOM NOM E30
JETSWU87's Avatar
JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87
could still be a coil/ignitor. Either pull the valve cover, or simply remove the oil cap and rotate the crank with a ratchet and see if the cams are moving.
JETSWU87 is offline
Old 05-30-2010, 11:55 AM
Ben L's Avatar
Ben L has disabled reputation
timing belt yo
Ben L is offline
Brian_O'Connor
03-28-2009 07:53 PM
vbspec
07-22-2008 04:34 PM
Scottyk6
01-02-2008 11:59 AM
xXThat GuyXx
01-01-2008 08:34 PM
Quick Reply: 1996 integra lost power on interstate will not start
