help, failed emissions
Old Jul 25, 2008 | 11:14 AM
  #31
Zero's Avatar
That's not gone well
Zero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud ofZero has much to be proud of
Default Re: help, failed emissions
Originally Posted by JSPITZ
Yes they are high and can take up to 15 psi on stock. I know of a few... over 600 whp 2zz celicas.
Impressive. I don't see many well-modified celica's these days. They're usually less than tastefully done and slow.
Old Jul 25, 2008 | 12:16 PM
  #32
BeefCake's Avatar
I'd rather have a celica. At least if I boosted the 2zz it would be better then that crappy ass 2.0..2.4 litre the SRT has. and my car look 3 times better.
The 2zz engine is in the lotus..don't see them using an eco tec
It's all good
are you fuckin serious??? the srt motor is way better than that crap 2zz. can handle much more stock. please show me a 2zz runnin 15psi all stock longblock and is holding up.
Old Jul 25, 2008 | 12:25 PM
  #33
Newbsauce's Avatar
1.6L Elitist
Newbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these parts
I'm all for decent compression motors running boost, but a 11.5:1 motor running 15 psi daily? Yikes, I'm not seeing it. I believe the exige is running about 7 lbs..so your saying simply double that and its gonna run all day?
Old Jul 25, 2008 | 12:33 PM
  #34
ravenracer's Avatar
Keeping It Real !!
ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer
when you are close to the emission shop swap the ecu with the stock obd2 do theemission and done .. swap the ecu back. I had obd2 boosted integra running a obd1 hondata chipped ecu. I just swapped the ecu with my stock one and finito . Just do it already ...
Old Jul 25, 2008 | 03:40 PM
  #35
klownh8er's Avatar
klownh8er is on a distinguished road
can't just switch ecu's wish it was that easy
sirii's don't have a crankshaft sensor so the ecu is gonna throw those damn cel's at me. what i would have to do is buy an obd2 oil pump hook up all sensors and hope to god a cel doesnt come on.
trying to find a different county at the moment though... cheapest way out
Old Jul 26, 2008 | 05:30 AM
  #36
JSPITZ's Avatar
Cyber Bully
JSPITZ can only hope to improve
no its not. The srt is just a bigger engine with lower compression, in terms of innovation, technology and craftsmenship the 2zz is better in every way. they do make lower comp pistons for the 2zz you know.
Old Jul 26, 2008 | 07:57 AM
  #37
BeefCake's Avatar
You said if you boosted it it would be better than a srt4. on stock internals you're wrong. that motor is a POS boosted w/o any internal work done.
then again the only celica even worth owning is an all-trac. the rest are bitch mobiles.
Old Jul 26, 2008 | 03:41 PM
  #38
dorifto83's Avatar
____________
dorifto83 dorifto83
TRUTH!!!
Old Jul 27, 2008 | 11:43 AM
  #39
JSPITZ's Avatar
Cyber Bully
aint that true
celica is just as much of a bitch mobile as any honda is, frankly I know more women that drive s2000's then men
suadi's gto
Jan 16, 2007 08:51 AM
Chezkers
Jul 17, 2006 05:14 AM
SBZRO
Jul 4, 2005 07:59 AM
VolvoTypeR
Mar 24, 2004 01:47 PM
