Electrical Problem
Old Aug 17, 2007 | 01:06 PM
93DOHC's Avatar
93DOHC is an unknown quantity at this point
Default Electrical Problem
I was riding my R6 the other night on the interstate and it just cut off, the lights were blinking etc. So the highway assistance people gave me a jump and my bike started and I hurried home. I replaced the battery and rode for a few days and it happened again. I'm thinking it's something like an alternator but I don't think bikes have alternators, I'm not sure? I don't know much about bikes. Some friends have mentioned my stator may be going bad...is that something that can easily be replaced? Any ideas...I know it could probably be a number of things, but sometimes taking it to the shop can get costly or is there any one up here pretty comfortable with working on bikes? Let me know, thanks!!
Old Aug 17, 2007 | 01:32 PM
Real Random's Avatar
Default Re: Electrical Problem
yeah my bike is doing the same thing
of course since i am bring it in to EMC soon I will have them look at it
::cough:: fullmetal ::cough::
Old Aug 17, 2007 | 05:02 PM
skr00zloose's Avatar
hatrs make me famous
it's either the stator, or the voltage reculator/rectifier.
there's only 3 parts to the charging system, and you've already replaced one. 9 times out of 10 it's the reg/rec, but a stator is a possibilty too.
if you have access to a voltmeter, you can check the stator output and that'll let you know if it's bad or not. there's no real easy way to test a reg/rec though.
Old Aug 18, 2007 | 10:26 AM
93DOHC's Avatar
I do have access to a voltmeter, but how do you test the stator? What do you hook it up to?
Old Aug 18, 2007 | 11:58 AM
simplsi's Avatar
Capt. Spaulding
simplsi has disabled reputation
Owning a r6 myself, and working at a bike shop, the Reg/Rectifiers on R6's take craps more then any other bike iv'e known.
Old Aug 18, 2007 | 02:20 PM
unplug the wires from the reg/rec, should be either 3 yellow, or 3 white wires. with the bike running, check the voltage between every combination of those 3 wires. i forget the exact specs, but if it's the about the same across all the leads, it's fine. the stator puts out A/C power though, so make sure you set the meter accordingly. negative to one wite (or yellow, some bikes are different), positive to another.
i'd be willing to bet it's the reg/rec though. be happy if it is, it's alot less work, and cheaper.
true, the only one's worse are f2's, f3's, and 900rr's.
Old Aug 22, 2007 | 04:47 PM
93DOHC's Avatar
I can't get the bike to run though...no power at all now.
Old Sep 4, 2007 | 12:05 PM
93DOHC's Avatar
Yep, it was my rectifier/regulator. Thanks
Old Sep 6, 2007 | 03:38 AM
did you go to a shop to get it fixed?
Old Sep 6, 2007 | 03:00 PM
93DOHC's Avatar
Yep...
importfanatic
Nov 17, 2008 06:38 PM
C Ory
Apr 15, 2006 10:25 AM
HMBeaty
Nov 11, 2005 08:11 PM
240dreams
Jun 16, 2004 09:06 PM
BadBeck
Dec 12, 2003 09:46 AM
