Xbox 360 in a car?
Old May 21, 2008 | 12:32 AM
  #21
Orange Face's Avatar
slippery when wet
Orange Face has disabled reputation
Default Re: Xbox 360 in a car?
the dc to dc thing would be complicated because the xbox has all kinda of complex shit with the plug.
rprsntng757 had a xbox in his car for a while. im pretty sure he didnt do it himself.
Old May 21, 2008 | 01:49 AM
  #22
Corey's Avatar
Yup, jolly poopbuggy
Originally Posted by Fabrik8
For the price of an inverter, I'm surprised no one has bothered to track down a switch mode power supply or DC/DC converter that can replace that big ass power brick. It's a huge waste of power to go from low voltage DC to mid voltage AC and then back to low voltage DC.
That's what they do for some carputers.
Old May 21, 2008 | 05:23 AM
  #23
Newbsauce's Avatar
1.6L Elitist
Newbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these parts
I personally run carPC's in my car. You will run into a huge problem with an XB360 vs a carPC: The draw of the XB360. CarPCs draw something ridiculously low, putting an inverter on your system will put a drain on the whole electrical system. Your best option is to run a dual battery setup, or upgrade your battery, and run the inverter DIRECTLY off the battery. They do have DC/DC connectors, but they require an ATX port on your mobo, and I've never personally opened an XB360.
Old May 21, 2008 | 07:36 AM
  #24
Corey's Avatar
http://www.carnetix.com/ They sell products for stuff like what you're looking for. Drop them an email and they may be able to set you up with something.
Old May 21, 2008 | 08:11 AM
  #25
I bet your carputer can't do graphics rendering like an XB360 though, and that's where most of the power goes. That and the XB360s don't use low power embedded processors because they don't need to (they're not meant for cars really).. So this is really a matter of which is higher performing vs. which is more efficient.
Old May 21, 2008 | 09:05 AM
  #26
Newbsauce's Avatar
1.6L Elitist
-231321 for a completely irrelevant post. My point was that a previous post was comparing carPCs to running the XB360 in the car. I was stating that there was a serious difference in power consumption and provided him with solutions. The reasons why the power consumption differs is totally irrelevant to the thread.
Last edited by Newbsauce; May 21, 2008 at 09:08 AM. Reason: Edited to be a bit nicer.
  #27
basketthis69's Avatar
All stock. No modify
basketthis69 has disabled reputation
You def need a bigger inverter. Don't hardwire the one you have with a bigger fuse. The fuse is there to prevent fires. No, not forest fires. CAR FIRES!!! Just spend the 60-70 bucks now and do it right or suffer the end result of your car burning down in flames. Which, would actually be pretty cool to watch (for everyone else) so make sure you at least let everyone know where it'll be at first. But really, don't put it in there. Or just get the proper product. Hope this helps.
Old May 21, 2008 | 01:29 PM
  #28
thgdfathr's Avatar
thgdfathr has disabled reputation
this just annoyed me. you want to see a car burn, go outside, stuff a rag in your gas tank, and light it up. dont post if it isnt anything new...i was told that 20 times already...and fuses are used to protect the wiring...not prevent fires. Im sure a hot enough wire would cause a flame, but thats not really the fuses job. Its so when you fuck something up and put too much electrical current into something, the fuse blows, instead of melting the near impossible to replace wire running under your dash. Anyways...back to the relevant posts...
My intverter is a 400 watt now. So you think hardwiring that to one battery would be too much, even if it is used rarely?
Old May 21, 2008 | 06:03 PM
  #29
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
Does the new one still blow your cigg lighter fuse?
Old May 21, 2008 | 06:07 PM
  #30
I'd hope so, cig lighters aren't fused that high. Every 10 amps at 12V is 120W, so do the math.
