Xbox 360 in a car?
Old May 20, 2008 | 06:39 PM
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
Default Re: Xbox 360 in a car?
What size fuse is in the end of the plug of the converter.
Old May 20, 2008 | 06:43 PM
I<3Strippers!'s Avatar
+RepCarebearCrew
google is your friend, thank me later
http://www.mechatroniks.com/wrx/xbox360.html
rustydailey's Avatar
rustydailey is an unknown quantity at this point
Just hard wire in the convertor.
Old May 20, 2008 | 06:44 PM
CRX
Make sure to fuse it. I install the heavy duty ones at my job.
Old May 20, 2008 | 06:57 PM
thgdfathr's Avatar
thgdfathr has disabled reputation
so hotwire it to the battery, but with a big ass fuse in between? sounds like a plan. ill let you know how it works out
Old May 20, 2008 | 07:01 PM
There you go, the answer is that you need a bigger inverter.
Old May 20, 2008 | 07:02 PM
thgdfathr's Avatar
the inverter seemed to work fine...so im hoping it wont burst into flames...i guess ill find out the hard way if it does
Old May 20, 2008 | 08:05 PM
No, its not working fine. You're blowing fuses.
There is a reason that you're blowing fuses, your inverter is undersized.
Old May 20, 2008 | 08:07 PM
chowe's Avatar
chowe has disabled reputation
Use a 400 watt inverter. Then run 10ga power to battery and a 10ga ground. What I do is 160 watts x2 = 360 so 400 watt = safe. Vector makes one, works great.
Old May 20, 2008 | 08:19 PM
For the price of an inverter, I'm surprised no one has bothered to track down a switch mode power supply or DC/DC converter that can replace that big ass power brick. It's a huge waste of power to go from low voltage DC to mid voltage AC and then back to low voltage DC.
