VTEC problems
Old Aug 29, 2005 | 12:56 PM
Default Re: VTEC problems
Compression. That's why. Octane rating is very directly related to detonation resistance and combustion stability, so high compression engines like B16s and B18C/C5 need high octane. It's only really needed for high RPM / high load though, if you're just running around town like an average joe then lower is fine.
Old Aug 30, 2005 | 11:12 AM
speedfreak165's Avatar
speedfreak165 has disabled reputation
I HAD THE SAME PROBLEM CHECK THE VTEC PRESSURE SOLINODE AND THE OIL LEVEL SOMTIMES THE SOLINODE GETS CLOGGED UP AND IT WILL MAKE IT DO THAT AND CHECK TIMING
Old Aug 30, 2005 | 07:14 PM
94silude's Avatar
89silude
94silude is an unknown quantity at this point
now that makes sense. it's not b/c it has vtec...but b/c of the compression. i couldn't for the life of me figure out what the octane had to do with vtec. thanks!
Old Aug 31, 2005 | 06:23 AM
undrpressure23's Avatar
pull you later
undrpressure23 has disabled reputation
you might even have to change your oil, i heard that if your oil is bad v-tech wont work correctly
Old Aug 31, 2005 | 03:20 PM
Your oil viscosity would have to be really high to make vtec not work..
B18A1 CRX
Dec 18, 2007 12:17 PM
Tim-Tim
Nov 27, 2007 07:30 PM
EGbobby
Dec 21, 2006 12:16 PM
zabbai23
May 15, 2006 04:45 AM
Cpt. Non-Spell
Jan 13, 2004 08:07 AM
