LS/vtec ECU problems.
Old Dec 5, 2006 | 01:49 PM
EGbobby's Avatar
EGbobby is on a distinguished road
Default LS/vtec ECU problems.
i have an ls/vtec in my 2000 hatch, it is an ls block with an ls crank eagle rods and ctr pistons and the head is a 95 gsr head with itr cams,dual valve springs and retainers, buddy club cam gears. its also got dc headers intake exhaust skunk 2 intake mani and adjustable fuel pressure regulator.
i just dyno'd my car today and it put down 160.5hp and is running very lien, and i think it should have put down way more then that, i am just curious what ecu i should be running because im not 100% sure??
Old Dec 5, 2006 | 02:01 PM
dc2stunna's Avatar
C.R.E.A.M
dc2stunna has disabled reputation
Default Re: LS/vtec ECU problems.
what ecu are you running now? you need to get that thing tuned. get w/ ross @ precision auto.
Old Dec 5, 2006 | 02:14 PM
tecnic1's Avatar
This is going to spo
tecnic1 tecnic1 tecnic1
that car needs engine managment in a really really bad way. There is no factory ECU that is going to run that engine correctly....
I'm gonna go out on a limb here and say it might need injectors too, but there is no way to know until you start tuning it..
Old Dec 5, 2006 | 03:33 PM
EGbobby's Avatar
the car currently has a p2t(99si) ecu.... it has an adjustable fuel pressure regulator and gauge so i am going to increase the psi like 10 lbs. and see what that does.
Old Dec 5, 2006 | 03:58 PM
tecnic1's Avatar
good luck with that.....
for real....you should at least put a vafc on the car. I know exactly what you are running, and I would not consider it particularly safe.
Old Dec 6, 2006 | 08:22 AM
EGbobby's Avatar
adjusting the fuel pressure regulator today. we'll see what it does!!
Old Dec 6, 2006 | 11:30 AM
thermal's Avatar
TurboPipingSystems
You should convert into an OBD1 then get a chipped/socketed ECU to run CROME. With that kind of modification you should get something to tune it with. OBD2 doesnt do you justice neither, since those ECU's are very prone to emission standards. Do you have an active CEL right now?
Bottom line, get CROME and talk to a tuner like MJ at Dyno Inc or mshue on here. These guys are more than capable...... GOODLUCK.
Old Dec 6, 2006 | 02:46 PM
Boi Boi's Avatar
Boi Boi is an unknown quantity at this point
tuning is the the key to get the most out of ur motor....
Old Dec 6, 2006 | 02:52 PM
slowb20civic's Avatar
VAdriven Sponsor
slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic
def. what thermal said...
CROME is the way to go, & Matt Shue is the man, his SN on here is --> sohc_mshue
Old Dec 6, 2006 | 05:07 PM
tecnic1's Avatar
Originally Posted by Boi Boi
tuning is the the key to not blowing up your motor....
fixed
