Recent Inspection Failure Info:
Old Sep 12, 2008 | 01:48 PM
  #21
DORKO's Avatar
Bearded.
Default Re: Recent Inspection Failure Info:
Originally Posted by ĦHombre!
Except that doesn't pass. The SRS light HAS to light up upon start up. If it doesn't come on, or doesn't shut off, it fails.
not if your car dosen't have airbags.
if you remove a airbag or airbags, you can remove the light.
If its not there how they can inspect it?
Old Sep 12, 2008 | 01:51 PM
  #22
elambz's Avatar
<3
You can argue with one of my inspectors if you'd like. If any part of the system is there, it all has to work. Just like the PS system and having a PS rack still.
Old Sep 12, 2008 | 01:57 PM
  #23
DORKO's Avatar
Bearded.
I am a state inspector..
like i said.
and if there is nothing for you to inspect, then how can you fail it?
thats just like failing someone for a blown FOG light bulb, and the car doesnt have foglights at all?
if the airbags are removed, and the brain box removed, the light can also be removed.
call trooper campbell. ill pm you his number.
Old Sep 12, 2008 | 01:59 PM
  #24
IMSHAKN's Avatar
IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN IMSHAKN
That's what he is saying...if the entire system is removed then there is no light.
With that said, it will still fail.
Originally Posted by 19VAC 30-70-290
E. Air bag and air bag readiness light.
Inspect for and reject if:
1. Any defects in the air bag system are noted by the air bag readiness light or otherwise indicated;
2. The air bag has been deployed and has not been replaced (and is not deactivated because of a medical or other exemption and a notice is posted to indicate that it has been deactivated);
3. Any part of the air bag system has been removed from the vehicle; or
4. If the air bag indicator fails to light or stays on continuously.
NOTE: Checking the air bag readiness light. Turn the ignition key to the on position; the air bag readiness light will indicate normal operation by lighting for six to eight seconds, then turning off. A system malfunction is indicated by the flashing or continuous illumination of the readiness light or failure of the light to turn on.
Old Sep 12, 2008 | 02:01 PM
  #25
elambz's Avatar
<3
like i said.
Sweet, but I didn't mention removing the brain, nor the passenger airbag. I was then suggested to take out the bulb, which won't make it pass. Please follow the thread.
Old Sep 12, 2008 | 02:03 PM
  #26
DORKO's Avatar
Bearded.
this is between you and the inspector of the car. If you show him that you do not have airbags in your vehicle, he can either call a trooper, or pass you.
the trooper will pass you b/c there is nothing to inspect, and it will not fail.
if you have SRS steering wheel still on the car, and the SRS dosent come on. then you will be failed.
if you have a MOMO steering wheel, and no SRS light, and a jdm airbag block off tray. you will pass.
Old Sep 12, 2008 | 02:05 PM
  #27
elambz's Avatar
<3
Correct, if there's no airbags, but I'd still have the passenger airbag and the brain there. I've been told it won't pass by multiple inspectors, and I won't go through the hassle of removing the brain and passenger airbag just to keep the steering wheel in it. I'll just buy a new SRS reel and steering wheel.
Old Sep 12, 2008 | 02:08 PM
  #28
DORKO's Avatar
Bearded.
well you could possibly get away with the SRS computer, b/c you actually have to look for that. and half the times, its under the dash, or under a seat or something weird.
as for the passenger airbag, that would either have to be removed, or blown.
you can have a blown airbag and still pass as well. as long as the light comes on, and goes off like its supposed to.
Old Sep 12, 2008 | 02:27 PM
  #29
elambz's Avatar
<3
Yeah. I refuse to remove safety features for other people, so I'll just put the steering wheel back to stock. I'd like to keep the wheel, but oh well.
Old Sep 12, 2008 | 02:31 PM
  #30
HatefulMechanic's Avatar
The Pro to call.
if the driver produces a disable form from the NHTSB, then it will pass.
its a giant cluster fuck, but a person can get a medical or other waiver and have the airbag system disabled in their vehicle.
but it has to have an exemption form and a notice in the vehicle.
