Recent Inspection Failure Info:
Old Sep 11, 2008 | 01:00 PM
elambz's Avatar
<3
Default Re: Recent Inspection Failure Info:
Since we're on the subject. If you remove your SRS steering wheel and replace it with a nonSRS wheel, it will pass correct? SRS only fails if the airbag is still present and the light is on, correct?
Old Sep 11, 2008 | 01:33 PM
The Wok's Avatar
DURRRRRRRRRRRRRRRRRR
You remove the airbag, light comes on, it fails.
Old Sep 11, 2008 | 01:41 PM
elambz's Avatar
<3
This shit is gay. Fuck driver's airbags.
Old Sep 11, 2008 | 02:19 PM
240trainee's Avatar
Stuff n Stuff
Yea, I've failed for PS before as well.
If its a PS system, it needs to function correctly.
Old Sep 11, 2008 | 02:27 PM
SortaFlush's Avatar
Slammedxpert
Originally Posted by JROW
I call bs on the power steering. It only has to work if it's there. If you take it out then it doesn't matter.
Can anyone verify?
Still has a Power Steering rack doesn't it?
Yes. It will fail.
If you guys have any doubts, call the state police I'm sure they won't mind to answer your questions.
Old Sep 11, 2008 | 08:25 PM
caeavesRSX-S's Avatar
before you were here
caeavesRSX-S has disabled reputation
The power steering rack just wasn't anything I'd ever heard about before and couldn't believe it. You would think you could remove any luxury item you wanted but the law says if a belt was on it then it needs to be present. I wonder if they look for the pulley to determine if the car had power steering. Would the CTR pulley be good enough to pass? I've already removed the pump,lines, hoses, and resevoir so putting it back isn't really an option.
I feel it steers with minimal effort and didn't think a manual swap was necessary but I guess a manual rack and quaife steering quickener would be the absolute way to solve that issue, but also the most expensive and time consuming.
I will also remove the back seat cushion and put it in the trunk for the next inspection.
I'm going to take it to a Honda place in Richmond next week because the guys there are comfortable with B swaps.
Old Sep 12, 2008 | 02:36 AM
Bizkit64's Avatar
No
Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64 Bizkit64
Go out in the country and get one done, they can care less out there
Old Sep 12, 2008 | 09:14 AM
SPAWN's Avatar
I <3 My DSM
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
i just failed my state inspection due to missing one lug nut on one of my wheels...i had four of the five...and i also had a bad turn signal socket (both fixed though and passed now)
Old Sep 12, 2008 | 10:02 AM
temp2's Avatar
temp2 will become famous soon enoughtemp2 will become famous soon enough
just disconnect the light socket plug to the srs light behind the cluster. It's what I did, passed fine. Even wired the horn with a makeshift pushbutton, doesnt have to be on the wheel at all.
Old Sep 12, 2008 | 01:40 PM
elambz's Avatar
<3
Except that doesn't pass. The SRS light HAS to light up upon start up. If it doesn't come on, or doesn't shut off, it fails.
