Leaking oil...
Old Jul 18, 2006 | 08:43 AM
j4k3's Avatar
holla
Default Re: Leaking oil...
Originally Posted by Cnu182
How difficult is that on a scale from 1-10?
Well seeing as you want something to hold it off untill you can take it somewhere it doesn't seem like changing a gasket is something you want to do.
Old Jul 18, 2006 | 08:47 AM
Spindrift's Avatar
psycho jungle cat
Originally Posted by 90_VertGT
Find where it's leaking from
If you really want it fixed this is your first step. Could be a simple oil pan gasket.
Old Jul 18, 2006 | 09:57 AM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
Get some engine cleaner.
Clean the oil soaked areas.
Add oil if you are low.
Inspect the leaks
Take picture if you are unsure of where its coming from.
Old Jul 18, 2006 | 10:18 AM
Cnu182's Avatar
Cnu182 is an unknown quantity at this point
Thanks for all help. I'm going to take it to my friend ricky and see if he can help me find out where it's comming from and what to do! Thanks again guys.
Old Jul 18, 2006 | 10:46 AM
92_SR20's Avatar
±RepLegion
92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20
Thank you sir
Depends on where the leak is coming from, something like a rear main, or front main I think you would want to bring to a shop, but if it's the oil pan or something semi-simple like that it's just a matter of having the gasket and the proper sealant.
Old Jul 18, 2006 | 11:19 AM
GaRn's Avatar
If you have over 100,000 miles, its probably the balance shaft seal, just happened to me.. you willl need to replace the seal and buy the retainer as well, to keep it from sliding out again. $10 worth of parts at the honda dealership or so..
another thing to check is the cam seal..
Also, I don't know if Accords have the water cooled sandwhich oil cooler, which goes in between the oil filter and the block, but the O-ring that goes between the oil cooler and the block is also notorious for leaking.. check for this, its obvious, it has coolant lines running to it and, well, goes in between the filter and the block, lol..
I doubt your front/rear main seals are leaking.. usually all of the above will go well before these will..
The only annoying one to replace really is the balance shaft seal, it requires you to take off the valve cover, crank pulley, belt cover, accessory belts, etc.. just to get to it, not much room to work with either..
atleast thats how it was on my car, and accords are very similar (you have an F22b1, SOHC VTEC I believe)..
Old Jul 19, 2006 | 06:42 PM
Dark-SRT4's Avatar
Ƴᴧᴍᴧӈᴧ
Dark-SRT4 has disabled reputation
Deal with the leak or find the leak and fix it.
Dont use the additives...they aren't good for the motor/oil system.
luv4ports
Jan 22, 2008 02:33 PM
DickButt
Feb 25, 2007 01:03 PM
ShaneJeffers28
Aug 1, 2006 03:40 PM
Moriar
Apr 21, 2005 06:53 PM
bseriesbenny
Mar 15, 2005 07:20 PM
