Leaking Oil
Old Jul 31, 2006 | 09:48 PM
ShaneJeffers28's Avatar
Hatch95gsr
ShaneJeffers28 can only hope to improve
Default Leaking Oil
The oil pan was stripped and oil was leaking out from under the bolt so i bought and oversized bolt put that in and it still leaks..the only other thing i can think to do is put some rtv on the bolt anybody else know anything...
Old Jul 31, 2006 | 10:28 PM
Hatch95gsr
Default Re: Leaking Oil
any suggestions?
Old Jul 31, 2006 | 10:38 PM
The_rabbit1's Avatar
Fidel runs VBPD
The_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud of
once the gasket goes bad you have to change the gasket. you can't just put another bolt or some rtv.
Old Jul 31, 2006 | 11:13 PM
99EJ6T's Avatar
Boosted F2B
Old Aug 1, 2006 | 07:29 AM
Ross's Avatar
Ross is an unknown quantity at this point
Get a new oil pan
Old Aug 1, 2006 | 07:40 AM
MerF's Avatar
Ghost
What are we talking about here, the drain bolt or just one of the bolst holding the pan to the block? If it's the drain bolt, then yes you need a new pan...which is not that expensive or difficult (use a new gasket).
Old Aug 1, 2006 | 09:45 AM
Hatch95gsr
yeah its the drain bolt
Old Aug 1, 2006 | 11:07 AM
MerF's Avatar
Ghost
Then it's settled. Good luck with it.
Old Aug 1, 2006 | 03:40 PM
Woodrow's Avatar
Slow as Shit
Did you re tap and thread the pan and all? Probably done with and time for a new pan.
luv4ports
Jan 22, 2008 02:33 PM
DickButt
Feb 25, 2007 01:03 PM
Cnu182
Jul 19, 2006 06:42 PM
Moriar
Apr 21, 2005 06:53 PM
bseriesbenny
Mar 15, 2005 07:20 PM
