Leaking Oil...
Old Apr 21, 2005 | 06:04 PM
Moriar's Avatar
Moriar has disabled reputation
Default Leaking Oil...
i seem to be leaking oil right around here...
now this is a BRAND NEW Turbo...
and yet i cant figure out to why it leaks..
Old Apr 21, 2005 | 06:08 PM
Keepin it Klean's Avatar
Clean Freak.
Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean
Default Re: Leaking Oil...
Have you made sure your oil fittings are tightened all the way? If you haven't you should sell the car.
Old Apr 21, 2005 | 06:09 PM
Moriar's Avatar
i tightend em to the point veins were poppin out my neck, yet there is still a slow drip or leak
Old Apr 21, 2005 | 06:10 PM
Clean Freak.
Ok, just making sure it wasn't the obvious. good luck
Old Apr 21, 2005 | 06:12 PM
BzTypeR's Avatar
04 M3
BzTypeR is an unknown quantity at this point
are there crush washers on them????
Old Apr 21, 2005 | 06:20 PM
Moriar's Avatar
yes
Old Apr 21, 2005 | 06:35 PM
gear's Avatar
Die reinste Bösen.
are they crossthreaded?
Old Apr 21, 2005 | 06:48 PM
Moriar's Avatar
im beginning to think so
Old Apr 21, 2005 | 06:53 PM
gear's Avatar
Die reinste Bösen.
that could be the only explination. My suggestion to you? the allmighty teflon+threadlock combo. Wrap the fitting in like 5 or 6 layers of teflon tape, then add some threadlock blue to the outside and retighten...allow to dry. If that shit leaks you can kick me in the nuts
luv4ports
Jan 22, 2008 02:33 PM
DickButt
Feb 25, 2007 01:03 PM
ShaneJeffers28
Aug 1, 2006 03:40 PM
Cnu182
Jul 19, 2006 06:42 PM
bseriesbenny
Mar 15, 2005 07:20 PM
