Wastegate Problem
Old Sep 7, 2006 | 05:47 PM
strtfightncivc2's Avatar
strtfightncivc2 is an unknown quantity at this point
Default Wastegate Problem
I have a turbonetics wastegate and the screw fell out of the top of it what are thing that can go wrong when that happens and how bad is it and i cant get another screw to go all the way in there.
Old Sep 7, 2006 | 06:47 PM
Default Re: Wastegate Problem
bump PLEASE HELP
Old Sep 8, 2006 | 06:52 AM
Old Sep 8, 2006 | 08:52 AM
Cpt. Non-Spell's Avatar
Speak&Spell Anyone?
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
You don't use that "screw" unless you have a manual boost controler, So it is pretty much function less other wise. So You shouldn't have a problem.
Correct me if I am wrong anyone
Old Sep 8, 2006 | 10:06 AM
i do have a manual boost controller....what exactly does that screw do?
Old Sep 8, 2006 | 11:27 AM
Speak&Spell Anyone?
It is for if you had a manual boost controler. You would put a vacume line from the boost controler to that and ajust boost that way.
Old Sep 9, 2006 | 05:11 PM
sohc_mshue's Avatar
Thats wrong. You are thinking of an electronic boost controller where you need to run a line to the top and side ports of the wastegate. A manual boost controller goes inline with your normal wastegate pressure source. The screw on the top of the turbonetics(if it is a deltagate) is for adjusting boost. If you tighten it you can get a little more boost.
Crcale
Engine / Exhaust / Drivetrain
Jan 9, 2009 10:07 AM
terryd123
Sep 24, 2008 08:36 PM
