Best oil?
Old Sep 9, 2006 | 03:54 PM
black6gen's Avatar
Turbo VTEC-E
black6gen can only hope to improve
Cool Best oil?
What would be the pest oil type for a turbo d16 at 10psi?
Old Sep 9, 2006 | 03:57 PM
bZeRk187's Avatar
bZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these partsbZeRk187 is infamous around these parts
Default Re: Best oil?
Redline or Royal Purple. Mobil1 if you can't afford the others.
Old Sep 9, 2006 | 04:17 PM
CHAHONDA's Avatar
corona connessuer
ditto
Old Sep 9, 2006 | 04:18 PM
CHAHONDA's Avatar
corona connessuer
wait....how many miles are on the motor?
Old Sep 9, 2006 | 05:03 PM
black6gen's Avatar
Turbo VTEC-E
92K but the hed is going to be pulled and replaced.
Old Sep 9, 2006 | 05:51 PM
eng's Avatar
eng
Administrator
eng eng eng eng eng eng eng eng eng eng eng
As long as you use the proper weight and change your oil regularly the brand makes almost no difference (i.e. super cheap stuff might not be the weight it says it is). The filter you use makes MUCH more of a difference.
The only reason to use synthetic is to go for extended intervals without changing, you should still change your filter though.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Old Sep 9, 2006 | 05:53 PM
black6gen's Avatar
Turbo VTEC-E
Ok, what about a special blend due to high RPMs? (8k)
Old Sep 9, 2006 | 06:05 PM
eng's Avatar
eng
Administrator
Don't recall of such an oil existing (even if one did seems like a bit of a scam). Usually you use a heavier weight oil when the RPMs (and turbos), hence heat, are high.
__________________
Old Sep 9, 2006 | 07:27 PM
anumeric's Avatar
anumeric has disabled reputation
+1 I also like amsoil as well.
Old Sep 9, 2006 | 08:05 PM
rollinna65's Avatar
rollinna65 has disabled reputation
German Castrol
