vw engine problems...
Old May 14, 2003 | 03:23 PM
slowgts's Avatar
slowgts is an unknown quantity at this point
yeah try carb cleaner, if the rpms go up youv'e found your leak
Old May 15, 2003 | 10:31 AM
Carter's Avatar
nannerpus, nannerpus
Originally posted by Dick
check injectors the o-ring just take a can of carb cleaner and spray around the intake and all vaccum hoses just dont spray to much carb cleaner is flamable or you can use propane to find your vaccum leaks
i'm confused. i think it might be my idle control valve... does that sound familiar?
Old May 16, 2003 | 09:00 PM
kutza's Avatar
Old guy
kutza is an unknown quantity at this point
also chk the rubber intake hose going to the t-body. I had a gti with one torn and the car drove funny and would die if in reverse, since the eng would tilt and open the hose up.
Old May 17, 2003 | 12:54 PM
Carter's Avatar
okay took it to a dealer... found out it's the mass air sensor. ~$400. not in my budget, but oh well. it had oil on it (i'm guessing that's not a good sign). is there a way i can just clean it off, or is it toast? thanks
Old May 22, 2003 | 07:07 PM
Carter's Avatar
fixed okay now... anyone know why my reverse gear pops out if i don't hold it???
tpage0007
Jul 24, 2008 10:21 PM
B18A1 CRX
Feb 20, 2008 03:41 PM
Qu33F
Nov 5, 2003 06:26 PM
