turbo problems
turbo problems
1998 Audi A4
Has the ko3 turbo and manifold.
Checked MAF and replaced every vacuum hose clamp.
Only when flooring it, my car stutters seriously between 3-4000 rpms. Just had a new turbo manifold installed...could it be a mis adjusted wastegate or the tune gone bad?
Please help
Please help
Originally Posted by ohTONYoh:8226247
hmm, turbo is aftermarket or stock? may be boost cut, or boost leak?
It's stock, it just started happening after the manifold was installed
Re: turbo problems
What is the boost doing under those conditions? Have you checked the TPS?
If you replaced one stock manifold with another stock manifold, it's probably something simple like a gasket leak. It's unlikely that an integral wastegate suddenly comes out of adjustment unless something got bent/damaged during the manifold swap.
No the wastegate is adjustable and I'm a novice to boosted cars, TPS meaning what? And the return line is attached to the manifold so I thought have been a vacuum leak
Re: turbo problems
Make sure your wastegate opens and closes freely, I know on my car if you put a new manifold on, it can block it from working correctly. And TPS is throttle position sensor.
Ok I'll check in the AM when it's cold. And I'll have to find the TPS. But taking it to cars inc tomorrow for a second opinion. Thanks!
