tire stretching help?
Old Nov 6, 2009 | 06:47 PM
iHeartTouge's Avatar
iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge iHeartTouge
Default Re: tire stretching help?
a 245/45 should be easy on a 10. what brand tire is it? some tires are just bitches to stretch. federals and falkens are the easiest i've come across to do. you can use a 16" inner tube for a bike tire to help seat the bead. pull it out when the bead is beginning to set.
Old Nov 6, 2009 | 10:42 PM
Cyanide Jello's Avatar
Zerofucksgiven
Originally Posted by RE-SPECGARAGE
that my set up. 245r 215f on a 17x10.
You dont need a cheata to do this. You just need someone that has done a few of them before. A 245 shouldnt need anything to mount them. If you are having problems you can bring it by my me. I done a few.
What I do:
1. set lower bead
2. take off shader valve and attach constant very low psi air.
3. get starter fluid on the upper bead. Make sure its all around
4. spray a little more starting fuild in the rim.
5. Use a long lighter.
AND BOOM. The tire should seat on rim.
PS> DO THIS AT YOUR OWN RISK>>>>>IM NOT LIABLE IF YOU BLOW YOURSELF UPOR DAMAGE ANY PROPERTY>>>
THIS!
Old Nov 6, 2009 | 11:21 PM
zenki godzirra's Avatar
VIP, doooood
zenki godzirra is a jewel in the roughzenki godzirra is a jewel in the roughzenki godzirra is a jewel in the roughzenki godzirra is a jewel in the roughzenki godzirra is a jewel in the rough
Originally Posted by upSLIDEdown
lulz @ calling that a stretch. I'm running a 225/40 on an 18x10.
Should be simple, maybe you're doing it wrong...
haha ditto
Old Nov 7, 2009 | 01:24 AM
BigHead Ted's Avatar
PandaMania
BigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these partsBigHead Ted is infamous around these parts
http://www.youtube.com/watch?v=n-LnkEUAImU
Old Nov 7, 2009 | 04:29 AM
RE-SPECGARAGE's Avatar
Danny@respecgarage
pm'ed
benjinos93
May 12, 2009 03:23 PM
idriveahonda
Wheels / Tires
Jan 4, 2009 12:03 PM
6spdeg
Sep 26, 2007 12:54 PM
japslapr
May 19, 2007 10:26 PM
matthew bryduck
Dec 12, 2006 10:58 AM
