Rpm Surge from 1200-3000
Old Nov 10, 2003 | 07:15 PM
sprack's Avatar
sprack is on a distinguished road
Originally posted by 94b18c1
whats the egr valve?
Exhaust Gas Recirculation
Old Nov 10, 2003 | 07:37 PM
94b18c1's Avatar
emmett18
94b18c1 has disabled reputation
ok i have cleaned the iac valve and put it back on, it still surges, i cleaned the TB still no change. the screw wasnt messed with either, should i play with it?
can it be the fast idle control valve
Old Nov 11, 2003 | 10:28 AM
sprack's Avatar
i think you over looked my posts...try these things.
egr valve, and pcv valve, iac valve
also..whens the last time you changed/cleaned the air filter?
Old Nov 11, 2003 | 01:05 PM
94b18c1's Avatar
emmett18
air filter dont remember, its been a while, iac valve checked and cleaned no change., where is the pcv valve and the egr valve?
Old Nov 11, 2003 | 01:08 PM
boostjunkie's Avatar
ITR prick #1...
boostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these parts
i really should put this in my sig....
but i think pyari chicks comment is better.
Old Nov 11, 2003 | 03:44 PM
94b18c1's Avatar
emmett18
ok i have the fast idle thermal control valve off, and the Tb. is there something i should do to the FITCV, the TB is clean, any suggestions,
ok i tightened the wax in the fitvc and the surging stopped for about 10 min after the car warmed but the idle was still high. then when i drove it an i guess the air cooled the car a lil it started surgin again, but not as rough.
is it defective or should i move on to something else?
Old Nov 12, 2003 | 06:14 AM
94b18c1's Avatar
emmett18
help!!
Old Nov 12, 2003 | 09:41 AM
PyAri's Avatar
PyAri PyAri PyAri PyAri PyAri PyAri PyAri PyAri PyAri PyAri PyAri
hahah i want a ride in the aaaar
Old Nov 12, 2003 | 12:29 PM
4nmusle's Avatar
06 blk 636
4nmusle is an unknown quantity at this point
you need to check the cel like I said!!!!!!!
I showed you how
Old Nov 14, 2003 | 02:50 PM
94b18c1's Avatar
emmett18
its was the fast idle thermal control valve, i tightened the wax, and now it runs normal, thanks 4 all the help.
ImprezedWRX
May 23, 2008 11:31 PM
k20egr
Feb 26, 2007 07:35 PM
gofastr110
Mar 28, 2006 01:57 PM
PRO-Habit
Jun 8, 2004 04:44 PM
385LT1
Aug 6, 2003 09:09 PM
