Relocating a battery to the trunk?
Old Jan 16, 2007 | 10:35 AM
CHAHONDA's Avatar
corona connessuer
Default Re: Relocating a battery to the trunk?
Originally Posted by Abysalone
Thanks PA, should I just ground the factory battery cable to the chassis in the front and separately ground the battery in the rear? Instead of running two wires back. Thats how ive always done it when I add a second battery.
So basically just hook factory +terminal to kill switch, then from kill switch to the + on the back battery? I just figured it wouldnt be that simple.
sounds right to me
Old Jan 16, 2007 | 11:31 AM
And don't forget the fuse or breaker in line with the cable at the battery end.
Old Jan 17, 2007 | 08:01 PM
Abysalone's Avatar
Fighterer
Abysalone will become famous soon enough
After some searching I found the easiest solution is to get a distribution block for the positive wires and run them all there. Easier to convert back this way too (which probably wont ever happen).
Hopefully this is right. I forgot the fuse in this drawing
Old Jan 18, 2007 | 01:59 PM
Matt64246's Avatar
Shift_N/a
Matt64246 has disabled reputation
Here's what mine looked like when it was all said it done, I didnt do the install of it, a VW guy , nissan guy ,and a honda guy did it for me. It was a Taylor Kit. pretty much took out the hot terminal(on my SR theres a screw that holds in all the cables that need power, and the one terminal that gose to the batt). and took out the ground. ran the cable from the bay, through the firewall, in the cabin to the trunk. mounted the battery, and made a good ground.
circled is where the old hot terminal was, the red cable is the new one that goes to the trunk.
thats the finished one, but I still need to get a box, and make a breaker switch for it..
92hondadriven
Mar 9, 2009 05:44 AM
Chezkers
Oct 18, 2007 06:32 PM
99CIVICFTW
Mar 25, 2007 04:14 PM
lindsey
May 22, 2003 05:22 AM
