overheating help
Old May 13, 2004 | 05:11 AM
  #21
s10lwrider's Avatar
s10lwrider is an unknown quantity at this point
Default Re: overheating help
First off i tested the old thermostat, it was bad. i also tested the new one it is good. replacing the thermostat helped a little, now it will idle without overheating but if i try to drive it it will overheat. I got a new radiator coming today that i will be putting in this weekend. The water pump and timing belt were replace back in december both were new from autozone. I have another water pump and a headgasket that i am going to replace both if replacing the radiator doesnt fix the overheating problem. Also when i change the radiator i am going to check all the hoses for any type of blockage. I havent check any fuses for the fans because both of them are on when it is overheating and off when it is idling. Also what is a thurmoswitch?
Old May 13, 2004 | 05:23 AM
  #22
Nato76's Avatar
The Comeback Kid
Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76
let us know when you fix your problem.
Moriar
Mar 3, 2006 04:44 PM
Moriar
Jan 5, 2006 09:42 AM
vasponger
Dec 16, 2005 09:26 AM
vasponger
Dec 12, 2005 07:42 PM
90 hatch
Jul 14, 2003 02:48 PM
