overheating:please help!
Old Jul 13, 2003 | 06:13 AM
90 hatch's Avatar
square1motorsports
90 hatch is an unknown quantity at this point
Default overheating:please help!
my car is overheating. it has a new thermostat. put on a new radiator cap. i let air out from the bleeder screw. it is sill overheating. it only does it whn driving the car. i will watch the temperature guage start to rise, pull over to pop the hood and the overflow bottle has 2 to 3 times has much antifreeze. it is just bubbling away. please help!
Old Jul 13, 2003 | 06:43 AM
Nic's Avatar
Nic
Nic Nic Nic Nic Nic Nic Nic Nic Nic Nic Nic
Could be any number of things...did you completely drain the radiator or just top it off when you replaced the thermostat? Was there any oil in the antifreeze? If there's no oil in there, I'd start with a coolant flush. As old as your car is, there's a good likelyhood of there being quite a bit of build up in the system.
Old Jul 13, 2003 | 07:13 AM
yeah flush that motha clean...................
Old Jul 13, 2003 | 07:26 AM
90 hatch's Avatar
square1motorsports
its already been flushed
Old Jul 13, 2003 | 11:24 AM
HMMM's Avatar
HMMM is an unknown quantity at this point
check if you leak any water on the driver side of your motor. if so, your water pump is bad
Old Jul 13, 2003 | 01:19 PM
90 hatch's Avatar
square1motorsports
no water leaking
Old Jul 13, 2003 | 02:36 PM
HatefulMechanic's Avatar
The Pro to call.
do you have any coolant circulation? what made you think the t-stat was bad? how long has this ben goin on? AIM me is the qucikest way for me to answer this for you...will be glad to help....
JOEY
Old Jul 14, 2003 | 04:23 AM
urvtecs2slo's Avatar
i like prom.
headgasket.
that is all.
Old Jul 14, 2003 | 05:51 AM
ToyotaTechGeek's Avatar
brake/steer/throttle
well, before you go headgasket, feel the hoses. make sure all of them are warm/hot. anyway, did you put the jiggle valve @ 2:30? did you open the heater core valve when you did all of the flush/fill/bleed work?
Old Jul 14, 2003 | 06:34 AM
drifterJERRY's Avatar
Lost Cat Magnet
drifterJERRY is an unknown quantity at this point
are the cooling fans working?
