need help ASAPls swap clutch problem
Old Feb 13, 2003 | 05:19 PM
jon's Avatar
jon
jon is an unknown quantity at this point
Default need help ASAPls swap clutch problem
just got done with a ls swap into a gsr, both are 1994's but one probem when we had the transmission out we replaced the clutch, the pressure plate, and the throw out bearing into the gsr transmission onto the ls engine. Now the clutch wont engage. What could the problem be? there is pressure in the pedal, the fork is hitting the throw out bearing, its just not engaging. We had the transmission torqued to specs also,, any help would be greatful, thanks
Old Feb 13, 2003 | 05:21 PM
rowe4166's Avatar
rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166
is the Fork moving ? Check your slave sylinder ? Do you have full pressure on the pedal ?
Old Feb 13, 2003 | 05:24 PM
jon's Avatar
jon
yes the rod in the slave cylinder moves as well ad the fork. The fork moves app 2.5 in. and its not a dead pedal not sure if full pressure
Old Feb 13, 2003 | 05:56 PM
jon's Avatar
jon
still baffled by it!!!!!!!!! the clutch engages when the car is off, but when i start it the clutch wont go into any gear
Old Feb 13, 2003 | 07:17 PM
slowgts's Avatar
slowgts is an unknown quantity at this point
is the clutch disc in backwards?
Old Feb 13, 2003 | 07:47 PM
rowe4166's Avatar
When you push the clutch in does the clutch pedal come back up by itself ? How many times did you bleed it ? do you have the car off the jack stands LOL
ridinboost757
Jul 15, 2007 11:18 AM
Bustadust
May 7, 2006 04:32 PM
GOOKY4U
Nov 18, 2005 09:54 AM
GOOKY4U
Oct 24, 2005 10:58 AM
LookslikeLS
Jul 13, 2003 10:00 AM
