LS/vtec ECU problems.
Old Dec 8, 2006 | 05:44 AM
  #41
Enigma's Avatar
Default Re: LS/vtec ECU problems.
Originally Posted by JayDM
Bobby, if you really want to see the potential of your motor, I'm sure I can get an AEM for you to dyno with.
AEM would be the prime choice
Old Dec 8, 2006 | 05:47 AM
  #42
JayDM's Avatar
All-Motor Street Car
JayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond repute
Originally Posted by Enigma
How high did you push the fuel pressure?
That is an old trick used in the V8's, not to be used on Hondas. These things have computers that do more than you can imagine.. use the computer. Here, pgmfi.org, go read up
If this is a LS/VTEC, get the VAFCII.. even though they are purely CRAP.. it is better having the ability to adjust the VTEC crossover points. Honestly, DON'T USE THESE.
Fuk an LS/VTEC.. save your money, there are better builds.
He bumped the fuel too high (60psi), but if you pay attention to the question I asked you, and figure it out, you will see that the car is not as lean as it sounds. I told Bobby not to go much over 5psi increase.
Old Dec 8, 2006 | 05:48 AM
  #43
EGbobby's Avatar
EGbobby is on a distinguished road
k well i just dont really want to spend more than $200 bucks because the gsr motor is going in soon. and if you can get an AEM for me to dyno with then i should not make that deal for the p28/safcII correct?
matt from millenium told me to turn up the fuel pressure about 10lbs. he said that it should have fixed it but it didnt. so i turned it back down to 48lbs.
Old Dec 8, 2006 | 05:49 AM
  #44
JayDM's Avatar
Gosh, I've had pretty good luck with LS/VTEC
276/170 all mota
*Im compressionfed on HT*
http://www.honda-tech.com/zerothread?id=1329162
Old Dec 8, 2006 | 05:51 AM
  #45
Enigma's Avatar
Use the computer, your pressure should only be about +5 psi over stock unless you just ahve an UBER turbo set-up and she just drinks fuel.
276/170 all mota
Those numbers aren't bad at all, but they aren't the best.
Old Dec 8, 2006 | 06:06 AM
  #46
JayDM's Avatar
Now you have deffinetly proven your ignorance. A 92mm crank b series with 276whp is in the top 1% of builds.
Matt from Abacus made 27x? with a 95 crank
Shad is right at the 280-290 mark with a big K motor
I have seen several 300+ B series dyno's that run on meth
I can tell you dont have much experience, other than surfing chat rooms.
Old Dec 8, 2006 | 06:16 AM
  #47
Enigma's Avatar
Alot of experience I am lacking, only surfing chat rooms is a big bust on your part.
Old Dec 8, 2006 | 06:17 AM
  #48
JayDM's Avatar
Not from the comments you make.
Better to be thought a fool, than to open your mouth and prove it...
Old Dec 8, 2006 | 06:19 AM
  #49
JayDM's Avatar
You have contributed no intellegint insight what so ever in this thread. The only knowledge you seem to shed light on, is to "TUNE" it.
Oh, and "uber turbo setups drink lots of fuel"
Old Dec 8, 2006 | 06:22 AM
  #50
Enigma's Avatar
Thanks
I'll go back to surfing the chat rooms, lol
