loss of power
Old 12-18-2010, 09:39 AM
its just a website
couped's Avatar
couped couped couped couped couped couped couped couped couped couped couped
Default loss of power
since ive gotten my car about 8 months ago ive been noticing a steady decrease in power, its only a d series and because of that ive been putting it on the back burner..
stock exhaust from the manifold to the muffler which is new oem
could this steady power loss be due to a clogged cat
any ideas such as plugs, wires, timing, bad air flow have been ruled out
appreciate the help in advanCe
couped is offline
Old 12-18-2010, 11:47 AM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
Default Re: loss of power
found your answer in the question
boredom is offline
Old 12-18-2010, 05:16 PM
5literbeater's Avatar
5literbeater has disabled reputation
could be a clogged cat or maybe a fuel filter becoming increasingly restricted. also check air filter
5literbeater is offline
Old 12-18-2010, 05:29 PM
mercuryman757's Avatar
mercuryman757 has disabled reputation
possibly a tired fuel pump or old fuel filter , or a weakening coil. whens the last time you did a tune up ??
mercuryman757 is offline
Old 12-18-2010, 05:38 PM
check the easiest , cheapest, and most common things before jumping to conclusions. if you need help ive been a mechanic for over 15 years . text me if you want its faster . 757 232 0740 .
Old 12-18-2010, 05:53 PM
its just a website
couped's Avatar
tune up done 3 months ago
i will replace fuel filter here soon just to do it, maybe thats it
possibly weakened coil or cat being clogged
will check in order from cheapest to most exspensive
i'll post back when i found problem
thanks everyone except first post
couped is offline
Old 12-18-2010, 06:04 PM
VaDriven Mayhem
Lord Humongous's Avatar
Ze truth...it hurts
Lord Humongous is offline
Old 12-18-2010, 06:25 PM
TAINT PUNCHER!
Slooby's Avatar
Easiest way to rule out the cat is to take it off if it is bolted up and if you can't see threw the pipe its shot.
Slooby is offline
Old 12-19-2010, 03:14 PM
hooking up a vacuum gauge is another way to check for clogged cat.
j4k3
12-25-2005 08:01 AM
EvolutionBoostin
12-24-2004 11:47 AM
MGBRaceman
09-12-2004 02:20 PM
Quick Reply: loss of power
