Honda question!!
Old Mar 31, 2007 | 05:43 PM
Don_is_Rad's Avatar
ooooooooooowwweeeeee
Don_is_Rad has disabled reputation
Default Re: Honda question!!
Do you think it too tight, or do you think it's my belt tensioner that is bad??
Old Apr 1, 2007 | 03:46 AM
Don_is_Rad's Avatar
during all this I broke the bolt holding the cam gear on so I took out the motor mounts on driver side on car and jacked the motor up a little. Then I drilled and removed the bad bolt and replaced it. Could I have damaged my rod bearing by doing so??
Old Apr 1, 2007 | 04:06 AM
Don_is_Rad's Avatar
http://cgi.ebay.com/ebaymotors/JDM-D...93612349QQrdZ1
I'm Thinking about just dropping the motor for this.
Old Apr 1, 2007 | 07:17 AM
kalel's Avatar
Ground Level Imports
kalel has disabled reputation
when the head was milled do you think that maybe it was too much. there is only so much you can shave off before the valves hit the pistons, maybe that is what is causing that thudding
Old Apr 1, 2007 | 10:28 AM
If you've got the head milled, did you get adjustable cam gears to adjust out the difference in belt spacing? If you didn't then you've changed your cam timing.
Old Apr 1, 2007 | 07:48 PM
99CIVICFTW's Avatar
RagPhoto.net
99CIVICFTW will become famous soon enough99CIVICFTW will become famous soon enough
changing cam timing shouldn't create a thud. it would just advance or retard the engine for either more acceleration or more top speed depending on which way it goes. take it to a mechanic and have them check the timing unless you can do it.
Old Apr 1, 2007 | 07:53 PM
99CIVICFTW's Avatar
RagPhoto.net
posible.
Old Apr 2, 2007 | 04:17 AM
Don_is_Rad's Avatar
One of my friends is going to look at it today at his shop, he thinks the belt is off by a tooth. That and I need to adjust my valves properly. Ill let you guys know and thank you for the tips.
Don
Slooby
May 22, 2007 09:17 AM
Will Sol
Feb 18, 2006 01:27 PM
jdmintegra
Oct 11, 2005 02:28 PM
27psi???
Jun 17, 2005 03:35 PM
drifterJERRY
Aug 18, 2003 06:57 AM
