Honda engines
Old May 22, 2004 | 09:33 AM
  #31
VT Prix GT 2006's Avatar
Motor Trend Mechanic
VT Prix GT 2006 is an unknown quantity at this point
Default Re: Honda engines
A lot of car companies have their variation of VTEC now. When VTEC was first introduced on the Honda/Acura NSX it was considered the most innovative automotive feats ever. And to think so many people make fun of it although half of them have no idea just smart and clever the concept truly is.
VTEC is used by a lot of automotive manufactures now just under different names so they don't get the fuck sued out of them (VVTL and VVTL-i from Toyota, MIVEC...I think thats the right acronym, from Mitsubishi, plus the technology in GM and Ford cars, although they don't have the cool acronyms like everyone else).
Old May 22, 2004 | 11:14 AM
  #32
leolo007's Avatar
leolo007 leolo007 leolo007 leolo007 leolo007 leolo007 leolo007 leolo007 leolo007
just a little correction, vtec was first introduced in a B16A in Japan in 1989.
Old May 22, 2004 | 11:25 AM
  #33
Meh, close enough.
Old May 22, 2004 | 11:32 AM
  #34
leolo007's Avatar
Originally Posted by VT Prix GT 2006
Meh, close enough.
is that Meh, supposed to be like dave chapelle in killing them softly?
cop: do you know why I pulled you over?
dave: Meh, cause Im black see. Meh!!
cop:stop talking like that!!
dave: stop talking like what copper? thats how I talk see MEEEEEEEHHH!!!
HAHAHA!!!
Old May 22, 2004 | 02:00 PM
  #35
Dave Chappelle=comical genius of our time.
If you're in college and you don't watch Dave Chappelle, you should die.
Why talk about variable valve timing when you can talk about the Chappelle Show?
Old May 22, 2004 | 04:19 PM
  #36
sk8rmike's Avatar
Bitches get Stitches
Originally Posted by nvrstock
yeah i wasnt thinking when i did the nissan engine explenation.
So when vtec kicks in it changes the cam so that the engine gets enough air. dosen't ford have soemthing like that in the focus?
simplified this is what happens.
each cam has 3 lobes...2 small lobes which are the low rpm lobes that act on the valvetrain at lower RPMs. the smaller lift/duration cams work good at making power under less airflow...when you hit a certain RPM these lobes start to become less and less effective. at this point the ECU checks for a certain set of parameters and if all are met (engine temp, engine speed, RPM, etc) then VTEC will engage. oil pressure is diverted to pins in the rocker arms that lock a normally disengaged arm and allow a much larger lobe to press against it and push on the valvetrain (keeping the smaller lobes from acting against them). this allows the valves to stay open longer and lift higher (better for high RPM power). on DOHC VTEC motors this happens on both cams. it's like instantaneously switching cams from a mild cam to a very aggressive one. on a SOHC VTEC motor only the intake cam lobes are affected. there is a version of the SOHC VTEC also, where one valve is designed to open slightly more than the other to swirl air coming into the cylinder for a cleaner and more efficient burn. this is called VTEC-e.
Old May 23, 2004 | 03:16 AM
  #37
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
Originally Posted by slowsilvercivic
why does my ls tach out at 7200 ????
Redline starts at 7200, or the rev LIMITER is 7200.i believe mark meant the redline starts at 6800
Old May 23, 2004 | 03:34 AM
  #38
boostjunkie's Avatar
ITR prick #1...
boostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these parts
Originally Posted by Boosted2003
you going to sing me that type r song? please oh please dustin.
if it aint a type R then it aint a tight car...
Old May 25, 2004 | 05:32 AM
  #39
giangsta's Avatar
giangsta is an unknown quantity at this point
the new si's are i vtec right?
Old May 25, 2004 | 05:37 AM
  #40
Yeah they have i-VTEC, meaning that both intake and exhaust valves will change lift. I always thought that Honda was releasing the Civic Type R in the states, although I have yet to see one on at dealerships.
