Help tuning carb
Old Oct 26, 2003 | 05:27 PM
xtremecapri1985's Avatar
xtremecapri1985 is an unknown quantity at this point
Default Help tuning carb
Anyone out there good at tuning carb or know someone that is
good. Let me know.
Old Oct 27, 2003 | 07:08 AM
MGBRaceman's Avatar
Iridium V
MGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond repute
Unless you are looking to replace jets, tuning a carb is fairly easy. There are two major components to a basic carb tune, the idle screw and the mixture screw. Every carb has these in different locations. In order to set your mixture and idle properly follow these instructions.
1. Raise your idle to 1000 RPM with your idle screw.
2. Adjust your mixture WAY RICH, (which is clockwise on most carbs) you may notice that the RPMs may drop when you do this, do not re-adjust)
3. monitor your RPMs as you slowly adjust the mixture screw leaner and leaner, they will climb.
4. Once your rpms peak and then drop off again, you've gone past the proper mixture for the motor, re-adjust rich until you peak the RPMs and your mixture is set.
5. After this, lower your idle to the recommended speed for that vehicle.
Old Oct 27, 2003 | 10:29 AM
IthinkI1's Avatar
Doin' it
IthinkI1 is an unknown quantity at this point
Nice capri.
Old Oct 29, 2003 | 02:22 PM
Carb? What's that? =)
Old Oct 29, 2003 | 02:43 PM
Blasphemous's Avatar
Former 757'er
Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous
It's that cheap alternative to EFI that still just won't die.
Old Oct 29, 2003 | 06:52 PM
drifterJERRY's Avatar
Lost Cat Magnet
drifterJERRY is an unknown quantity at this point
or you can be crazy and remove the FI system and put in carbs..for no real reason what so ever.
Old Oct 30, 2003 | 04:35 PM
ToyotaTechGeek's Avatar
brake/steer/throttle
sorry, i haven't messed around much with Holley carbs. i know Webers, though! good luck!
Old Oct 30, 2003 | 05:29 PM
Former 757'er
What kind of Holley do you have? I have a 4150series 650 DP, it was pretty easy to tinker/tune with.
Old Oct 31, 2003 | 06:37 AM
MGBRaceman's Avatar
Iridium V
I've been dealing with Webers as well.
WutupYo
Mar 3, 2009 08:14 AM
alcfourlife
Dec 31, 2008 04:38 AM
s2k7
Jul 30, 2004 01:32 PM
