Help SR20det wont start!!!
Originally Posted by kota2240
how much oil do these motors ask for, someone told me 3??? when i changed the oil it seemed like 5qts came out.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
The idle is rough, keeps revving up and down, ill check the motor tommarow once all this rain is out of the way. Ill keep you guys posted
I Think that your smoke will go away,
But It sounds like your timming is off still......It could be what SR PWRD was telling me last night, (My timming is off) It will run but if the timming is right but if the crank/cam angle sensor is off it will run like shit......
Your ECU problem was settled right?
last but not least check your 02 sensor, if its bad your car will run like shit........
To address your idle problem if you dont find it to be the cam angle sensor or the 02 sensor, it might be a AIC problem......Check to see if all your vacume lines are hooked up corectly, and dont forget to check the element in your MAF........
As far as everything else goes I cant think of anything else that would throw your idle off........
-Jeff
yeah i asked the same question on shiftva, the IACV how do i clean it and where is it exactly located or is it called AICV same thing i believe
Replace it.........91 classic SE-R SR20DE cant remember the part #.....
goto this link, it will help u immensely, http://srswap.com/faq2.htm
LOL are you talking to me?
ROTFLMAO..................
no, i meant to the other guy, sorry, and that link is for the part number of the part's
Oh.....Its cool.........I thought you were calling me out on the 91 SER parts that were interchangeable.......No harm no foul........
I got the motor running GOOD!!!
I got it to trun over by using the phase2 motor trend instructions for timimng and I banged out the center of the oil pan even it though it looked perfect. The whole pan must have been pushed upwards when sitting on the pallets making it difficult to see the imperfections. So no that the motor is getting oil, My valve noise are GONE!!!!.
I took it for a test drive and the SR FLYS!!!!!
Thanks everyone for your input!
I got it to trun over by using the phase2 motor trend instructions for timimng and I banged out the center of the oil pan even it though it looked perfect. The whole pan must have been pushed upwards when sitting on the pallets making it difficult to see the imperfections. So no that the motor is getting oil, My valve noise are GONE!!!!.I took it for a test drive and the SR FLYS!!!!!
