H22 vtec problem
Old Apr 13, 2006 | 02:16 PM
josemata's Avatar
joseh22
josemata has disabled reputation
Default H22 vtec problem
hello. My friend put an h22 into my 95 hatchback. VTEC wont work. it might be bc the SRS light comes on? the check engine lights stills comes on. i also ordered a new ECU, wich i thought might be the problem. but its not. can anyone help me.
Old Apr 13, 2006 | 02:37 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
Default Re: H22 vtec problem
VTEC wiring, wired up? What all did you "use from the old motor" or is everything for THAT specific motor? What code's do you have...??
Old Apr 13, 2006 | 03:06 PM
josemata's Avatar
joseh22
me friend checked all the wires. we used everthing new for the swap. he said it might be bc the SRS lights comes on. When VTEC is supposed to work, the motor stalls about 5000 to 5500 RPM. he cheked the codes and it says VTEC is not working
Old Apr 13, 2006 | 03:17 PM
Try VTEC solenoid, Try taking the "SRS" system fuse out, reset the ecu. And try again.
Old Apr 13, 2006 | 03:20 PM
madcatz's Avatar
Prelude Whore
madcatz has disabled reputation
SRS messing up Vtec?
SRS is supportive Restraint System....Airbags and Seat Belts...I have a SRS light in my 98 SH and my Vtec works fine....forget about the SRS light right now.
what codes are you throwing?
Old Apr 20, 2006 | 04:47 PM
josemata's Avatar
joseh22
i found the problem, its the vtec solenoid
Old Apr 22, 2006 | 04:04 AM
Slepping_H22_DC's Avatar
I am SLOW SON !!
Slepping_H22_DC has disabled reputation
i could of told you that. always start with the manual 12v vtec engagement method. rule of thumb
strokerace
Apr 14, 2008 11:36 AM
p-stone
Jun 17, 2007 11:00 AM
phxaz
Mar 14, 2005 06:34 PM
gen4H22A
Feb 8, 2005 09:04 PM
DanielSanderson
Feb 8, 2005 10:07 AM
