h22 throttle body problem
Old Jun 16, 2007 | 07:00 AM
p-stone's Avatar
Uno Mas
p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone
Default h22 throttle body problem
Car is 93 Prelude, stock h22a1. I removed the throttle body to gain access to my heater core. I didn't remove any of the coolant or vacuum lines, only unplugged the sensor (TPS, I believe) When I put the car back together, I now have a high pitched whistling sound and the idle is screwed up (rev to 2.2k and then back down on it's own like a bad IAC does) The whistling wasn't there when before I removed the TB and it idled fine as well. Did unplugging the TPS reset something?
Old Jun 16, 2007 | 07:08 AM
integrarj's Avatar
Default Re: h22 throttle body problem
did you put the tb gasket back on, and tighten the TB. also if its the stock gasket that was on it i would reccomend replacing it cause its old and im pretty sure thats what it is
Old Jun 16, 2007 | 07:09 AM
integrarj's Avatar
or you dont have a vaccum line hooked up
Old Jun 16, 2007 | 07:12 AM
p-stone's Avatar
Uno Mas
Well theres only one vacuum line from it that goes to the MAP sensor and thats still hooked up. Going to get a new TB gasket and will try again
edit - gasket ordered, won't be here until tomorrow. I found out the whistling noise I'm hearing is coming from the fast idler valve. When I plug the hole inside the throttle body the noise goes away although the idle doesn't get any better.
Old Jun 16, 2007 | 08:48 AM
integrarj's Avatar
did you tighten the fast idler valve all the way back up
Old Jun 16, 2007 | 09:09 AM
p-stone's Avatar
Uno Mas
I never touched it whatsoever ... I will look at that as well.
Old Jun 17, 2007 | 10:00 AM
Uncle Tattoo's Avatar
yeah tip assist!
Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo Uncle Tattoo
buy my wheels and the sound will go away. seirously check your pm im tired of waiting.
Old Jun 17, 2007 | 11:00 AM
MajorsEF's Avatar
MajorsEF will become famous soon enough
its ur tb gasket, make sure u get all the remains off the im and the tb itself then put ur new one on
vwhondaman
Engine / Exhaust / Drivetrain
Mar 3, 2009 06:51 AM
cleanEK
Want to Buy / Trade ARCHIVE
Oct 13, 2007 06:02 PM
CHAHONDA
Jan 21, 2003 05:22 AM
