GSX mods for the track
Old Nov 20, 2002 | 07:30 PM
  #21
BoOsted's Avatar
BoOsted is an unknown quantity at this point
As far as boost goes, I run 14psi daily using 550s and an AFC and im still running rich. Pat runs about the same psi on stock fuel injectors and no fuel controlers. Bumping your system to 15psi using the basic map settings on Road Race Engineerings website in conjunction with an aftermarket pump, everything should be straight.
One more thing, if you need injectors I have some 550s im getting rid of. just PM me if interested
Old Nov 20, 2002 | 09:15 PM
  #22
HighPSI TSi Guy's Avatar
❒Good ❒ Better ✔Best
Originally posted by BoOsted
If that were the case than exaust wrap would be a pro not a con. Concidering that the wrap would keep the heat from the exaust in the pipe instead of seeping out.
that's another good point. thanks for making my head hurt
Old Nov 21, 2002 | 10:07 PM
  #23
MeanGreenGSX's Avatar
INCONCEIVABLE!
MeanGreenGSX is a name known to allMeanGreenGSX is a name known to allMeanGreenGSX is a name known to allMeanGreenGSX is a name known to allMeanGreenGSX is a name known to allMeanGreenGSX is a name known to allMeanGreenGSX is a name known to all
It works just plain in simple that it keeps the parts that are ment to be hot stay hot and what is sopossed to be cold stays cold.
Old Nov 22, 2002 | 08:50 PM
  #24
turbochad's Avatar
turbochad is an unknown quantity at this point
Wrapping your exhaust won't really hurt anything. What it will definatly do is lower your oil temperatures since the d/p runs under the oil pan.
The theory that some people use is that if you wrap the down pipe, you are keeping the gas hot, which is expanded. As the exhaust cools, it condenses. As to will this make an effect on your car? Probobly not.
On the boost subject, I run 18psi on the street with my 17C. I've got 550's, Walbro FP (hardwired), VPC, AFC and a Charged Air Adjustable FPR. I've got my fuel trimmed pretty good except at idle. At idle it sucks completely because of the cams I have, not nearly enough vaccum so it runs so rich it's not funny. On a 16G, you should be able to go better then 10psi with 450's. I would assume 15, but don't quote me on that, I have a 1G.
Old Nov 23, 2002 | 08:14 AM
  #25
Big 16GSX's Avatar
formerly 99gsxturbo
Big 16GSX is an unknown quantity at this point
I ran 14 psi at the track yesterday and was detonating at the top of 3rd. My AFC values were all set to 0. My 02 voltage when I heard the first pop was .87v. I still ran a 13.8 @ 97mph on a 1.93 60'. I must have detonated and let off the gas right before the finish line, because a run I made on the stock turbo, I hit 14.1 @ 99mph. That was the only pass I made all night. I'm not going to run again until I get the car tuned professionally with larger injectors.
Old Nov 24, 2002 | 03:35 PM
  #26
dude.. didn't you run race gas? with some 100+ octane in there you should have had no problem with 14PSI
  #27
Old Nov 24, 2002 | 05:59 PM
  #28
Big 16GSX's Avatar
formerly 99gsxturbo
I had 3.5 gallons of sunoco 112 and approx. 2 gallons of 93. It didnt make sense to me either.
also I know i was burning the leaded gas because i had white smoke comming out of the tailpipe
Old Nov 25, 2002 | 12:12 PM
  #29
Ninety7GSX's Avatar
No Name Who?
Ninety7GSX has disabled reputation
Leaded gas. Not 02 sensor friendly. : (
Old Nov 25, 2002 | 05:37 PM
  #30
INCONCEIVABLE!
prepare to buy a new o2, i ran 3 gallons of 116 1 time and it was shot
