grinding first gear
Old Feb 19, 2009 | 01:12 PM
Turbobrick's Avatar
executive member
Turbobrick Turbobrick
Default grinding first gear
What would be the likely cause of this, considering I haven't been hard on it(no powershifting, clutch drops). It recently started happening and occurs more frequently after the car has been driven for awhile. Transmission is a 5spd, RWD getrag.
Old Feb 19, 2009 | 04:29 PM
Default Re: grinding first gear
Might need a fluid change. Grinding after the car has been driven for a while sometimes means the fluid isn't doing a great job at temperature anymore.
Old Feb 19, 2009 | 05:23 PM
RandomTask's Avatar
What car is it?
What fabrik8 said, in order;
Fluid
Not enough action on the T/o bearing (bleed it)
dead syncro
Old Feb 19, 2009 | 05:38 PM
Turbobrick's Avatar
executive member
Fluid was changed ~10K ago.
Car is a 93 volvo 940 turbo but the transmission is from a euro spec 940. I'lll bleed the clutch tomorrow and hope for the best.
Old Feb 19, 2009 | 05:45 PM
Might just be a worn synchro then. Also check for a loose shift linkage or a sloppy/worn shifter bushing.
madmortar
Jun 4, 2008 11:05 AM
cleckner04
Feb 14, 2008 04:23 AM
urvtecs2slo
Mar 18, 2006 03:22 PM
WOODman
May 26, 2005 06:07 PM
rsdancel
Jul 6, 2004 09:28 PM
