Full throttle boost problems
#21
Re: Full throttle boost problems
Originally Posted by Jarrod
Mine look like that. I haven't check them in a while. Time to turn the fuel pressure down....
#22
braap braap
Originally Posted by Enigma
Ya man.. you might wanna look into that before you push that thing anymore...
But I turned it down; and I'ma drive around normal. I've been doing alot of city driving, and since the fuel pressure is up more than the stock; I think thats the reason why.. It certainly loves it up top though...
good gas mileage and throttle response>having .5 peak hp more.
(I'll P.M. you and update you on the plugs, but it ain't no biggie.. I work at Honda now
#23
I don't wanna jack this thread anymore.
Maybe you can help this kid get his shit running right..
#25
Funny noone has mentioned anything about a missing link/check valve..
Do you have a missing link/check valve?
If you don't, as soon as your MAP sensor senses boost, it goes f*!kin nuts.. lol
#26
has a missing link, timing is regular and they are regular plugs, should i run a colder plug or sumthing? and about timing, what is a good thing to help timing temporarly till i get hondata
#27
I would run 1 step colder on the plugs, retard timing 2 deg for 5-7 psi..
the timing COULD be your problem, however I doubt it..
what does it feel like? does it just fall flat on its face and feel like you hit a brick wall, or does it just feel like it lost power at full boost? does it buck?
make sure you missing link is working correctly..
