A few more problems with the b16 crx
Old Jun 16, 2004 | 07:13 AM
dorifto83's Avatar
____________
dorifto83 dorifto83
Default A few more problems with the b16 crx
Thanks for helping me with my idle problem I had before, I have a few more questions though. The car is a 1990 crx hf w/ a b16a, whenever I put the car in reverse, the autometer tach reads whatever the motor is reving at, but the car's stock tach drops to zero, and the car starts running a little rough. If I give it gas, it has no problem, but it almost feels like it has a short somewhere. When I asked on hondaswap, they said that when you swap a b16a into an hf there are 3 wires you had to change, but nobody could tell me what or where those 3 wires were. Ok, 2nd problem is the car came with an aftermarket pilot steering wheel that didn't have the horn hooked up. I took it apart this weekend trying to get the horn to work, but I couldn't find it. Does anybody have a wiring diagram for a crx, I can get one by this weekend, but if somebody has one available, then it would just save me some time. The last problem I have is the car has kyb 4 way adjustable coilovers, and the suspension squeaks when I go over bumps and stuff, but it also squeaks a lot when I steer on level surfaces. Has anyone had that problem before, I haven't messed with it yet, but don't really know how it would be fixed. Thanks in advance once again for any help.
Old Jun 16, 2004 | 09:58 AM
Runnin13s's Avatar
Runnin13s is on a distinguished road
Default Re: A few more problems with the b16 crx
well the whole reverse thing im not sure if ur having the same problem but with me everytime i went into reverse it would throw a code (engine coolant temp) for some odd reason ..this has happened in 3 other crx with b16 swaps that i know of all where hf's i just had to unplug 2 wires from my tranny then it stopped throwing a code and it started to run normal only problem is i dont have reverse lights anymorei dont know if this helped u at all but that was my problem
Old Jun 16, 2004 | 09:54 PM
deeseetoo's Avatar
NO MA'AM
deeseetoo has disabled reputation
for the steering wheel you need honda part number 35259-SH3-A02
its a shoe horn that fits non srs steering wheels
Old Jun 17, 2004 | 08:11 AM
dorifto83's Avatar
____________
dorifto83 dorifto83
that is fucking weird, the car sometimes shoots a code 6 and goes into safety mode where it doesn't let me shift past 7000 rpm. Any ideas besides on unplugging those cables?
Old Jun 17, 2004 | 09:25 AM
Runnin13s's Avatar
really ?? that shits different .. mine has never done that and it helped mine ...sorry
Old Jun 23, 2004 | 06:00 AM
dorifto83's Avatar
____________
dorifto83 dorifto83
finally fixed the car, no reverse problems or CEL codes. On hondaswap.com they told me to look at the pinouts, that the crx hf has an extra wire that the crx si doesn't have. I looked at it, and it is in the B plug, B9 (green/black) once I cut it, I still had my reverse lights working, and the car wouldn't act weird anymore and no CEL lights would turn on anymore. I still have to fix the horn, but I think I can figure that one out. Does anyone have any ideas on how to stop the squeaking from steering and suspension? Thanks for the help though.
akintg95
Nov 1, 2007 02:29 AM
eghondafamily
Oct 30, 2007 07:19 AM
spider228
Mar 20, 2007 03:03 PM
NORIDE:(
May 16, 2006 10:49 PM
sikkcrx
Jan 19, 2004 12:55 PM
