Idle Problems - '91 CRX w/B16
car: 91 crx Si w/ b16a1 swap..
Problems: when i first start the car it takes a few seconds to start up and when it does it starts a really low rpm like 500 unless i give it a little gas..
2nd problem: once the car has started and i drive for a couple minutes and i go to a stop light the car will stay at a grand for a little then will drop down to 500 and then 300 and start to act like its going to cut off and then i give it a little gas and it goes to a grand and then does the same thing...
Re: f*ck
i apologize for my mispelling of vtec..the brand of phone i have is vtech and it was just coincidence that it was sitting right infront of me when..o f*ck it no since in trying to deffend myself
I have a 20 valve...
Re: f*ck
Originally Posted by FastCrxVaWLude
possible vac leak. check your IACV an your FITV too
beat me to it. If your hood is unpainted, you should have a diagram (even though its for the d16) and just make sure all vacuum lines are run correctly. 90% of the time, its you have a tube not hooked up or in the wrong spot.
