eclipse spuddering problem
Old Apr 9, 2005 | 06:09 AM
legitCRX's Avatar
legitCRX has disabled reputation
Default eclipse spuddering problem
my eclipse pudders betwenn 1 and second gears i figured it was my plugs and wires so i changed them from advanced. Still did not work so went to bapgeon and said advanced gave me german plugs so i bought some from there. Worked alot better then before but still a little bit. then the wires advanced gave me shreaded while taking them out like 5 minutes after installing so returned them and placed stock ones back in there. so now i have new plugs with original wires still puddering alot less then initially. should i go and buy newer wires which are better then advanced or try somen else?
Old Apr 9, 2005 | 09:29 AM
sk8rmike's Avatar
Bitches get Stitches
Default Re: eclipse spuddering problem
what you really should've done is checked the stock plugs to check for signs of running rich, running lean, detonation, etc. that would help diagnose the problem a lot more. misfiring by faulty plug wires generally occurs more at a lower rpm under a heavy load so keep that in mind. also you may possibly have a fuel filter getting clogged up. just try to figure out what is wrong before you go throwing parts at the car.
Old Apr 9, 2005 | 03:22 PM
integra-t's Avatar
Jump In
integra-t has disabled reputation
my car does the same thing..some one reccomended checking the air/fuel ratio
or the car could ot be getting enough fuel and too much air resulting in a lean position
as soon as you step on the gas a bit does it clear out???
blackdragon6784
Sep 21, 2007 05:08 AM
CivicRenModelX
Jun 24, 2007 11:23 PM
sglover1227
Jul 22, 2006 05:16 PM
Boostedb20vtec
Apr 27, 2006 01:07 PM
g S x
Jan 11, 2003 01:58 PM
