cr-vtec??????
Originally posted by 0psi
The actual cylinder strength can be increased and you can use a longer rod and custom pistons with raised pin sets to help out the side wall loading and R/S ratio. The block is a good starting point if you want to take the time and effort to correct its "problems".
Originally posted by Fabrik8
By the time you correct the "problems" you might just as well buy something else for all the money you just spent in rods, parts, etc..
I guess you could always try to stroke the dog piss out of a b18 and run a very short rod and custom pin set piston, but what would be the point.
Not necessarily. Basically your only other option to reach 2.0 liters is to sleeve a b18 block and that would be more expensive to do then the process needed to strengthen the b20 cylinders.
Originally posted by VTECnology
why not just run a Type r motor. Don't you think if a B20 VTEC was a better motor Honda would have produced it?
EDIT: Should i just build an ls-vtec then? if the block is so much weaker?
gotboosthatch
Dec 18, 2008 03:55 PM
Woodpsuher50mm
Want to Buy / Trade ARCHIVE
Jun 1, 2008 06:34 PM
Tim-Tim
Jan 29, 2008 07:19 PM
