cr-vtec??????
Old Feb 7, 2003 | 07:29 AM
Wii's Avatar
Wii
Retired OG
Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii
I give Skunk2 a holla. They build a Bad ass B20/VTEC
CR-V Block with a Type R head.
Old Feb 7, 2003 | 10:05 AM
Flite's Avatar
HHIC
why not just run a Type r motor. Don't you think if a B20 VTEC was a better motor Honda would have produced it?
Old Feb 7, 2003 | 10:16 AM
LookslikeLS's Avatar
Dont sleep
LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS LookslikeLS
did honda produce the LS/VTEC motors??? no tuners figured out that the ls block had more torque capabilities than a gsr or typr r. thats why the crv-vtec is just as if not more potent than a ls/vtec.
Old Feb 7, 2003 | 01:32 PM
Boosted2003's Avatar
well shit fuck doing all that jsut turbo a ls block best weigh to go or maybe turbo a b20 engien hm... lots of torque?
Old Feb 7, 2003 | 07:08 PM
Flite's Avatar
HHIC
everything is a compromise though. Sure you want that torque of the LS or B20 but if you're going to put the VTEC head on it and try to rev it, it's not going to last. It won't take the abuse that a true VTEC motor will.
Old Feb 8, 2003 | 10:41 AM
94b18c1's Avatar
emmett18
94b18c1 has disabled reputation
the block are stronger, so whats the problem, where can he go wrong?
Old Feb 8, 2003 | 11:53 AM
S dot Camp's Avatar
Asshole Supreme
Famous misconception of the crv blocks. They actually are weaker and can not handle high cylinder pressures.
Old Feb 8, 2003 | 11:54 AM
S dot Camp's Avatar
Asshole Supreme
Originally posted by Boostfed
YUP! Now if I can find a CRV blco cheap then I'll drop that in the Coupe and have fun. How's your motor coming along Scott?
I am actually taking a break at this very moment from assembling the short block. The head should be back late next week or early the following week.
Old Feb 8, 2003 | 01:50 PM
CRV blocks are notoriously weaker, yes. You'll also come out with a wierd rod to stroke ratio and a long stroke that won't like high RPM at all. It's truly a big comprimise frankenstein. If you want a 2.x liter VTEC, get an H22..
Old Feb 8, 2003 | 04:02 PM
S dot Camp's Avatar
Asshole Supreme
The actual cylinder strength can be increased and you can use a longer rod and custom pistons with raised pin sets to help out the side wall loading and R/S ratio. The block is a good starting point if you want to take the time and effort to correct its "problems".
