Cooling problems
Old Sep 10, 2004 | 08:33 AM
13thDVL's Avatar
13thDVL is an unknown quantity at this point
Question Cooling problems
My fan motor for my acura integra isn't working so right now my car is over heating. I just ran the fan to a swich but it didn't go on...The motor is bad. I in turn ran the switch to the Ac fan which was still working. It cools a little better but not all the way. I was wanting to know if I could just take out my whole fan assembley and use a two electric fan s or just go ahead and replace the fan motor. I am going to turbo it in the future.
Only talk if you know what you are talking about.
One.
Old Sep 10, 2004 | 09:20 AM
MGBRaceman's Avatar
Iridium V
MGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond repute
Default Re: Cooling problems
Well, for the most part, you can just go and replace the fan itself with a Spal or hayden cooling fan. Both will cool better than stock usually. Local auto parts stores carry only generic replacements, so if you're looking for something that will fit like the origional you'll need to go to the dealer. But if you want to modify you can go with the spal high CFM + an aluminum radiator. These fans can also be wired up to your OE fan activation circuit if you so please.
Old Sep 10, 2004 | 02:59 PM
NIC668's Avatar
You dont know if you can swap out fan motors but you are going to turbo you car...HA good luck
Old Sep 10, 2004 | 05:34 PM
13thDVL's Avatar
Thanx for the optimism.
bobbyteenager
Mar 27, 2008 03:32 PM
nogo1231
Oct 11, 2006 04:57 AM
Enigma
May 22, 2004 04:37 AM
Banshee
Jul 23, 2003 04:23 AM
