Cam Gear alignment. NEED HELP!
Old Dec 10, 2006 | 02:27 PM
ls96swap's Avatar
ls96swap has disabled reputation
Default Cam Gear alignment. NEED HELP!
Well I put some adjustable cam gears on and my exhaust side is off a half a tooth. The timing belt is off but I cant adjust the cam gear to where its perfectly aligned with the intake side. Does anyone know how to move it so it realigns again? thanks for the help.
Old Dec 10, 2006 | 02:30 PM
1rude2l's Avatar
Default Re: Cam Gear alignment. NEED HELP!
the cam gear only moves the cam not the outside where the teeth are make sure you didn't move your crank at all when you installed the cam gears
Old Dec 10, 2006 | 02:48 PM
ls96swap's Avatar
I know I didnt move the crank bc its still at tdc. But how can I fix the fact that Im off by a half a tooth?
TurboEG8
Dec 2, 2008 02:34 PM
1rude2l
Sep 24, 2008 03:47 PM
Slow93hbSi
Feb 10, 2008 04:43 PM
