boost problem :( :( :( HELP
Old Mar 22, 2007 | 02:32 PM
blasko's Avatar
THE FIASCO
blasko is on a distinguished road
Default boost problem :( :( :( HELP
ok, todays project was installing a Hallman Manual Boost Controller.
i was told to take the line off the turbo that runs to the #2 solenoid.
- run line from turbo to BC inlet
- take line from solenoid #2 to wastegate actuator and unplug it from the wastegate
- run line from BC outlet to stock wastegate actuator.
now i can only get 4lbs of boost no matter what the BC setting is.
am i missing something? hooked up right? do i NEED to bypass that solenoid?
broken boost controller?
help. 4lbs sucks. im used to 12 on street tune, and i want more, not less.
Old Mar 22, 2007 | 06:25 PM
1ns0mniac's Avatar
we PARTYIN!
1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute
Default Re: boost problem :( :( :( HELP
if the hallman is anything like the turbosmart manual boost controller then you should be running the "T" "inline" with the compressor and wastegate
it seems what you described is correct
the fitting at the top of the wastegate should be open w/ no vaccuum lines attached.
one vaccuum line goes from compressor to the actuator on the wastegate. cut in the middle of that line and install the boost "t" correctly there.
should look like this:
COMPRESSOR>>>>>>>>BOOST CONTROLLER>>>>>>>WASTEGATE ACTUATOR
..make sure the boost controller inlet and outlet are facing the correct way.
brandon.beene
Jul 24, 2009 02:44 PM
spider228
Dec 8, 2006 11:19 AM
ls/vtec hatch
Nov 10, 2006 06:19 PM
Randy@FMS
Oct 16, 2005 08:28 AM
g S x
Jan 11, 2003 01:58 PM
