boost problem
Old Nov 8, 2006 | 07:12 PM
ls/vtec hatch's Avatar
ls/vtec hatch has a spectacular aura aboutls/vtec hatch has a spectacular aura about
Default boost problem
ok i have a hatch with a ls boosted when the turbo full spools up it feels like the car hits a brike wall and wont take the air any know anything??
Old Nov 9, 2006 | 05:27 AM
Ross's Avatar
Ross is an unknown quantity at this point
Default Re: boost problem
How many pounds are you running? What are you using for engine management? What is done to the fuel system?
Old Nov 9, 2006 | 05:30 AM
evolve's Avatar
evolve evolve evolve evolve evolve evolve evolve evolve evolve evolve evolve
sounds like fuel cut
Old Nov 9, 2006 | 05:39 AM
thermal's Avatar
TurboPipingSystems
Fuel cut...... if you have an electronic management or an EBC. Get your set-up tuned!
Old Nov 9, 2006 | 05:40 AM
black6gen's Avatar
Turbo VTEC-E
black6gen can only hope to improve
Im with him.
Old Nov 9, 2006 | 07:24 AM
yea stock ecu with stock injectors running a fmu with a aem fuel rail and missing link....so should i upgrade my injectors to a 450 or 550??
Old Nov 9, 2006 | 03:01 PM
thermal's Avatar
TurboPipingSystems
Are you using any kind of electronic boost controller? Fuel cut has nothing to do with your injectors. Fuel cut is the same as boost cut. If you are using an electronic boost controller (EBC) or a some kind of electronic fuel management that monitors boost, you could be hitting fuel/boost cut.
For instance, if your wastegate is set at 10 psi but you are spiking boost to 14 psi, your EBC or electronic fuel management will see that boost spike and control (cut-off) fuel to drive your motor slower. This is a safety function so you do not blow up your motor from overboosting.......
Old Nov 9, 2006 | 04:08 PM
i have a boost controler but its not electronic and i also have a external wastegate im not sure of the lbs on it tho
Old Nov 9, 2006 | 04:17 PM
Atlantis's Avatar
OV-104
Might want to find out the lbs
Old Nov 9, 2006 | 04:28 PM
Boi Boi's Avatar
Boi Boi is an unknown quantity at this point
i think it will help the people out here thats trying to help u out if u tel them ur set-up....
