Best timing belt???
Old Aug 4, 2007 | 03:19 PM
HatefulMechanic's Avatar
The Pro to call.
Default Re: Best timing belt???
Gates is the OE manufacturer, you can get them at Napa, Carquest, or any parts store that sells gates.
and that is a goddamn good price on the OE belt, NONE of my suppliers have it at that price. i would be weary.
Old Aug 4, 2007 | 03:50 PM
Sherdog9's Avatar
Sherdog9 has disabled reputation
Originally Posted by RPRacing
that belt is ok as it is from Honda. just make sure you dont get non OE stuff.
While you're in there, do T belt, water pump, valve cover gasket, plugs, wires, valve adjustment, may want to do the 2 cam seals and the cam end plug too.
If you want cams/gears, yes do them now as labor will be none for them (unless they need springs/ret)
here are what i will buy:
>timing belt
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=005
>water pump
>valve cover gasket
>steam seal???? this one??
>cam end plug:
do I need belt tensioner and head gasket?
Old Aug 4, 2007 | 07:49 PM
flat's Avatar
Blah!
flat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these parts
Why not just go to honda and not risk getting ripped on ebay.And know your getting the right parts and quality parts at that.My advice Just go to honda
Old Aug 5, 2007 | 08:17 AM
The Pro to call.
you do realize what is involved in replacing valve stem seals?
Old Aug 5, 2007 | 09:23 PM
krazdracer's Avatar
krazdracer has disabled reputation
Originally Posted by Sherdog9
I thought you were just going to replace the timing belt????
Old Aug 6, 2007 | 08:58 AM
Sherdog9's Avatar
I want to change all at once to save time and labor cost. I did not know stem valve is that hard to install.
Old Aug 6, 2007 | 12:03 PM
krazdracer's Avatar
Are you doin the labor??? if you use compressed air to keep the right tools it not to hard.
oxsleeperxo
May 15, 2008 03:38 PM
Si2See
Oct 18, 2007 04:21 AM
Touge180
Jul 6, 2006 05:41 PM
B16CRXsi
Jul 29, 2004 06:32 PM
Kaedenky
Nov 27, 2003 04:31 PM
