Best timing belt???
i can only assume you are asking about abelt for a honda. if so, use Stock belt and pump. I use them on all my builds. they are great for any built or stock motor.
thanks a lots guys..... yes, it's for my GSR engine.... I'll go with OEM belt + water pump. I was reading at Greddy timing belt but well I trust OEM more
..... where should I buy to get the REAL belts? Ebay has it but i am not quite sure it's real or not. here is the links
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
what do i need for complete timing belt change?
>timing belt
>water pump
>valve cover gasket
>timing belt tension???
>head gasket at the same time?
Should I go with cams + cam gear at the same time to save labor cost?
..... where should I buy to get the REAL belts? Ebay has it but i am not quite sure it's real or not. here is the linkshttp://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
>timing belt
>water pump
>valve cover gasket
>timing belt
>water pump
>valve cover gasket
>timing belt
>water pump
>valve cover gasket
>timing belt
>water pump
>valve cover gasket
>timing belt
>water pump
>valve cover gasket
While you're in there, do T belt, water pump, valve cover gasket, plugs, wires, valve adjustment, may want to do the 2 cam seals and the cam end plug too.
If you want cams/gears, yes do them now as labor will be none for them (unless they need springs/ret)
sure. but why pay more for a belt when most of the high HP turbo cars are running OE Honda belts? The Honda belts are great. I rev to 10k rpms and i feel safe with the stock belt.
