b20 vtec
Old Jun 8, 2006 | 04:25 PM
Yell88CRXsi's Avatar
Team Ultraspeed
Default Re: b20 vtec
There's a saying that, "All the power is in the head" So with that...what you choose to do to the head is going to determine how much power you make, for the most part. There are always varables.
As far as the rod to stroke ratio...I wouldn't focus too much on it. Yes it is true that lower rod ratios do not like to rev sky high on stock rods, but that is easily fixed with a set of forged rods. It's also true that higher piston speeds cause more wear n tear. But lower rod ratios do have there advantages like higher torque with lower RPMs. Playing with rod ratios is something that you should leave alone if you do not understand they're cause and effects.
Old Jun 8, 2006 | 04:53 PM
LLama's Avatar
Unconfirmed User
LLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond repute
Just wondering...
why are people doing b20 swaps? Aren't they only rated at 126hp/122tq non-vtech, and 146hp/133tq v-tech? Just wondering why not go for the b18c1? The b18c1 weighs less also right?
Correct me if I'm wrong... I'm sure there's some advantage to it.. i'm just ignorant to it.
Old Jun 8, 2006 | 05:12 PM
Team Ultraspeed
Originally Posted by LLama
Just wondering...
Torque
Old Jun 8, 2006 | 05:19 PM
LLama's Avatar
Unconfirmed User
Originally Posted by Yell88CRXsi
Torque
b18b 142hp/127tq
b18c1 170hp/128tq
If these figures are correct... I don't see sacrificing that much top end for 5 ft lbs of torque...
Old Jun 8, 2006 | 05:21 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
Just wondering...
Aren't they only rated at 126hp/122tq non-vtech, and 146hp/133tq v-tech? Just wondering why not go for the b18c1? to it.
Idk why people would put B-series phones in there cars anyways.
Old Jun 8, 2006 | 05:22 PM
LLama's Avatar
Unconfirmed User
What kind of power are the b20/b16 head conversions putting out?
What all is involved in doing the head swap... bottem end work?
Old Jun 8, 2006 | 05:38 PM
Team Ultraspeed
It really depends on the build. A 84mm+ bore (B20 or sleeved B18C) with a 89mm crank (B20 or LS) with some forged piston (11.5:1 + cr) and forged rods with a real ported vtec head, upgraded valvetrain, some stage 2+ cams, an ITR intake manifold, a 65mm+ throttlebody, 310/320cc injectors, a half way decent header, and an AEM/Hondata/Crome could get you 220whp & 150lbs.
Thats 260 flywheel hp compared to a 160 or 175 of average stock vtec motors.
Old Jun 8, 2006 | 05:58 PM
LLama's Avatar
Unconfirmed User
84mm+bore... that's stock b20 right?
89mm crank... stock b20 also right?
So just dropping the forged pistons and rods in....
Then the built b16 vtec head... a little air and fuel.... that's it?
I'm with ya now.... People go b20 just for building purposes....
Just curious, what all is involved in the b16 vtec head? just the pistons/rods and the bottom end can handle those high rpms right?
Old Jun 8, 2006 | 06:11 PM
LLama's Avatar
Unconfirmed User
Another question... on a b18b block, you can't do the b18c1 vtec head on it without doing some bottom work end can you?
What about the b16 vtec head on the b20 non-vtec motor? Also... is there a power difference between the b16 vtec head on the b20 non vtec motor vs the b20 vtec motor?
Sorry, I'm full of questions.
Old Jun 8, 2006 | 07:01 PM
Team Ultraspeed
Any B series vtec head will fit on any B series block.
Power output will depend on what is done to the motor.
