B20 swap info
Originally Posted by MP5
Or you could have faith in a STOCK B20b and run 14lbs of boost daily for 8 months while putting 50-100 miles on it a day delivering pizzas and not have a problem with the motor like me.
Thanks for you help mp5, but I have read your thread. You are one of the few that is actually running that set up. Thanks for you input, but I am trying to see if anyone else is running it. All I know is that there are alot of people out there that don't run the same setup but only read about it. I just need more assurance because I already order my b20. What kind of turbo setup u're running? I am worry because this is my 3rd motor. Thanks again man.
When i had a bone stock B20b i ran a friend with a B16 hatch with some minor bolt ons and we stayed side by side on the interstate from about a 60-100 roll or so.
I got a Jdm B20B in my integra, using a Skunk2 Intake manifold. I like it a lot, but thinking about dropping a turbo kit on it and pushing about 7psi daily. Good info MP5. Glad to see the motor can hold at least 14 psi. ANd I agree with the tuning part.
Motor is about to go in. Put new water pump, timing belt, alternator belt and clean out some other bs. Question what Distrubitor do i do use? I am running the wiring harness from a 00 civic ex coupe. I also need "air intake temperature sensor", the one the intake manifold fartherest right on the passenger side. Where can I find that? Other than that I think I am set. Motor is going in tonight. Thanks again in advance for all your help.
spnamnt
Jul 19, 2008 09:14 AM
