B18a1 Oil Leak Problem!!!
Old 10-08-2010, 07:40 AM
zachsta92's Avatar
zachsta92 zachsta92 zachsta92 zachsta92
Default Re: B18a1 Oil Leak Problem!!!
Ya I guess that's not too bad,but the only thing is if I do it I don't wanna fuck up and make the leak worse
zachsta92 is offline
Old 10-08-2010, 08:52 PM
White Devil's Avatar
If the main seals are leaking, you should be looking at replacing ALL the other seals you can get to. You might as well, since youll be taking a lot of stuff off the car to get to everything.
White Devil is offline
Old 10-09-2010, 04:05 AM
tre4s13's Avatar
tre4s13 has disabled reputation
rear main seals dont leak anywhere cept in the transmission..... nor would it even be near the exhaust. try checking your valve cover, the back nuts might stripped...i hate caps. if it's not that then its your cam seals, distributor....gl.
tre4s13 is offline
Old 10-09-2010, 06:01 AM
zachsta92's Avatar
Ya I figured I would try to replace some other stuff while I'm there, I might as well u know
And r u sure it if the seals bad it wouldn't drip on the exhaust its right above it.
Liquidgsr
02-29-2008 06:51 AM
sebassttiann
12-12-2005 10:53 AM
94_CRVtec
08-24-2005 02:32 PM
VT Prix GT 2006
05-28-2004 08:02 PM
Quick Reply: B18a1 Oil Leak Problem!!!
